Rough running Z1 900
Hi, my Z1 is running really rough. Just had the petrol tank lined, carbs cleaned and new plugs fitted. On starting it pops and farts running on 3 and occasionally 4. Where would be a good place to start. TIA.
- warren3200gt
Re: Rough running Z1 900
If its running at all the tank/tap must be supplying fuel so carbs, either bad clean job or need setting up properly.
Float height, bench sync, vac sync, mixture.
Ok, thank you for your reply. I will try and get the carbs set up and balanced.
You wouldn’t know a local reliable person by any chance ?
Rpp999 wrote:You wouldn’t know a local reliable person by any chance ?
you may want to contact Dave Ennis @ Buzzworkz, Hampton, London - link to facebook -
https://www.facebook.com/BuzzWorkz/
an article on his work link - https://www.visordown.com/feature/road- ... lding-guru
- warren3200gt
If your in Bexleyheath, I'm just by Bluewater. Don't profess to be an expert but built and re commissioned plenty of Z"s
I agree Dave Ennis is a good commercial bet.
Thank you for taking the time to reply. Will certainly make contact.
- warren3200gt
Replied.
All sorted now. Thanks to an extremely nice and helpful club member. You are a legend.
- warren3200gt
Not a problem Ray, no one on here likes to hear of a poorly Z and not try to help.
warren3200gt wrote:Not a problem Ray, no one on here likes to hear of a poorly Z and not try to help.
Nice one.
ADRIAN H wrote:warren3200gt wrote:Not a problem Ray, no one on here likes to hear of a poorly Z and not try to help.
Nice one.
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
