900 rear wheel spacer dims
- RALPHARAMA
Anyone able to tell me the dimensions of the spacer that goes between the sprocket carrier and the inside of the swinging arm on an A4?
Can’t find one so need to make one .
cheers
Ralph Ferrand
- warren3200gt
Re: 900 rear wheel spacer dims
Assuming they have stock. Alternatively measure internal and external dims from carrier and axel. Width is 11mm.
https://www.z-power.co.uk/rear-axle-col ... 977---1981
A lot of seals have their dimensions printed on the outside face in a series of a group of three numbers. You might be able to read the seal dimensions, which would give you the outside diameter too.
- RALPHARAMA
All made and ready to be fitted .... all I have to do now is find what I did with the bag of brand spanking new cush drive rubbers
It's only a dry build so I can leave the rubbers out for now. They'll come to light when I have bought a new set on the final build
Ralph Ferrand
Users browsing this forum: No registered users and 100 guests
