Z1000 Ltd rear M/c
Z1000 Ltd rear M/c
Anyone know where I might find a rebiuld kit for a Z1000 Ltd, the one with the long brake rod?
Steady Eddie #21
Skunkwurcx
I ended up getting the bits from Kawi, which do not come as a "kit" for my '77 LTD. I had ordered an aftermarket one from the dealer originally, but when it arrived I found it was the wrong one. The manufacturer of it had listed that it would fit the years with the fluid cup on the unit, when in fact it only would fit the years where the fluid cup is seperate and connected via a hose.
Hope this helps.
Andrew
Hope this helps.
Andrew
Andrew,
Is this like yours? Click on the thumbnail for a larger version
David
[img][img]http://img410.imageshack.us/img410/9674/ltdmcsz3.th.jpg[/img][/img]
David
Steady Eddie #21
Skunkwurcx
