530 chain length Z1000R
#1 PostAuthor: chrisNI » Sun Oct 30, 2022 6:59 pm
Could anyone give me a ballpark chain length for 1000R with 530 chain? It had a chain on it but I cannibalised it many years ago to use on my Z1000 I guess I could count those and add on the bit that’s still in the drawer but an idea of what it might be would help. Should have taken notes. :vstoopid It’s running 16/35 as it’s got 17” rear wheel. Any ideas anyone. Rough idea will help :D :shock:
Re: 530 chain length Z1000R
#2 PostAuthor: Al » Mon Oct 31, 2022 1:47 pm
98 links at 630 would convert to 117 links at 530 under normal circumstances but that would be with an 18 tooth 530 front and a 49 tooth rear at 530. (standard 15 / 41 at 630)
I have an 18 tooth front and a 45 tooth rear at 530 and 114 links at 530 with an 18 inch rear wheel but with a 60 profile rear tyre which will be fairly close to a 17 inch wheel with standard size tyre profile.
Not sure how you are getting away with 35 teeth on the back sprocket even with a 17 inch wheel unless you are aiming for the outright land speed record and are being pushed up to 70 MPH before dropping the clutch on first gear. :D
#3 PostAuthor: chrisNI » Tue Nov 01, 2022 11:40 am
Al wrote:I have an 18 tooth front and a 45 tooth rear at 530 and 114 links at 530 with an 18 inch rear wheel but with a 60 profile rear tyre which will be fairly close to a 17 inch wheel with standard size tyre profile.
Dunno Al as far as I know I’m running what was on it before I took it off the road and it was fine then, I’ll have to recount my teeth
#4 PostAuthor: chrisNI » Tue Nov 01, 2022 6:59 pm
After a recount back appears to be 45 I don’t know why I thought it was 35 :shock: probably best to count the links on the Z1000 and add the cut off bit
Users browsing this forum: No registered users and 91 guests
