I hoped to avoid lining my ELR tank, when i cleaned it with Biox I found it was weeping around the badge fixings. I looked at replacing it but it is hard to find a good tank that is not in similar condition. I soldered it and checked it again and found more weeps. This went on for 3 or 4 times, so even now it is water tight I'm not confident it will stay that way for long. I was speaking to a lad who was into those horrible Hodnas and he recommended this product. have any of you any experience with it?
https://wagner-german-oil.com/wagner-tank-sealing
If I could sort the tank one way or the other I can get the paint work done and that's me sorted. This has held me up since April.
Thanks in advance,
P
Tank liners
- warren3200gt
Re: Tank liners
No experience of that product but have used POR 15 a few times successfully. A 250ml tin is enough for one tank.
https://www.frost.co.uk/por15-fuel-car- ... KIQAvD_BwE
Re: Tank liners
Pot 15, is a good product if done properly, but is a devil to get out.
Personally I think it is better to repair the tank and not use a liner. Especially as it’s being repainted,
Re: Tank liners
Yes I agree but There were so many pin holes that think it will be a waste of time to get the tank sprayed unless it is lined.
I hadn't see this before and hoped it was an improvement over the other liners. It claims to be ethanol proof, but so does this:
warren3200gt wrote:No experience of that product but have used POR 15 a few times successfully. A 250ml tin is enough for one tank.
Thanks for the replies lads. I need to get off the fence one way or the other shortly!
Re: Tank liners
I lined my tank in Aug 2020 with POR15, only two years but still good.
Not sure if you've seen this thread I put on, might be of use.
Stu
viewtopic.php?f=32&t=47199
Stu
Re: Tank liners
My H tank needed doing as it was like Swiss cheese and getting a replacement likely impossible
I ended up getting it done 5 years ago by a company called TCP tank care products
Not the cheapest approach maybe but fixed once and for all.
Re: Tank liners
chrisu wrote:My H tank needed doing as it was like Swiss cheese and getting a replacement likely impossible
Thanks for the reply Chris, did TCP weld/patch the tank or line it?
P
Re: Tank liners
Skid Mark wrote:chrisu wrote:My H tank needed doing as it was like Swiss cheese and getting a replacement likely impossible
P
Probably both
But not sure
Bottom was cut and welded back
H tanks rarer than rocking horse poo
Re: Tank liners
Tank care products do treatment kits, I've used them twice and had no problems. The first kit I used needed the tank and sealant jollop to be heated to something like 70 degrees C, which was a pain. The kit I used a couple of years ago had been reformulated somehow and only needed heating to 30 odd degrees (I think...) to get it to flow and was much easier to use.
It's a pain of a job but worth doing in my view if you do it properly.
Olly
Olly
Lemmy
Lemmy
Users browsing this forum: No registered users and 83 guests
