Gearbox Bearing
PhilMill63
Gearbox Bearing
#1 PostAuthor: PhilMill63 » Thu Dec 01, 2022 6:05 pm
Hi All, I've pulled off the outer gearbox cover behind front sprocket and I've found the gearbox bearing behind the sprocket is knackered, glad I ended up pulling it apart rather than riding it. Anyway, I found a part number 92045-021, but other then CSNL I'm struggling to find a replacement, and CSNL want 187eu which seems crazy for a bearing. Any suggestions where to source this? I'm guessing its a relatively normal bearing other than the grove for the retainer?
Phil
'76 Z900A4, '76 Suzuki GT750, '83 RD350 Hybrid and too many projects!
z2.john
Re: Gearbox Bearing
#2 PostAuthor: z2.john » Thu Dec 01, 2022 6:18 pm
You must get a C3 fit if you find an alternative. This is slightly looser tolerance to allow for heating up from cold to hot engine
Skid Mark
Re: Gearbox Bearing
#3 PostAuthor: Skid Mark » Thu Dec 01, 2022 10:23 pm
z2.john wrote:You must get a C3 fit if you find an alternative. This is slightly looser tolerance to allow for heating up from cold to hot engine
would you mind expanding on this please John?
z2.john
Re: Gearbox Bearing
#4 PostAuthor: z2.john » Fri Dec 02, 2022 8:52 am
To quote from a bearing manufacturer:..............
"Internal clearance being C3 means that the bearing has room for expansion if needed between the races of the bearing, whilst holding the outer ring and moving the inner ring in a radial movement you will detect a little amount of play between the two rings. All standard clearance bearings have this movement, it may only be a small amount of movement but is controlled by international standards. C3 means the bearing has more clearance than standard.
For example we may use C3 clearance on bearings where a cold start up application may cause the balls to heat up quickly, the heat needs to go somewhere. Some of the heat gets passed through the outer race to the housing and the inner race to the shaft, this causes expansion which closes up the clearance in the bearing. If you did not allow for this clearance the bearing would not have room for expansion and lead to bearing failure.
It is never advisable to replace a bearing with one having a lower initial clearance. By the same argument, it is usually safe to substitute a larger clearance when the desired clearance is not available."
Re: Gearbox Bearing
#5 PostAuthor: chrisu » Fri Dec 02, 2022 1:47 pm
Skid Mark
Re: Gearbox Bearing
#6 PostAuthor: Skid Mark » Fri Dec 02, 2022 6:25 pm
Another wrinkle in my arse! :up
Mr Bump
Re: Gearbox Bearing
#7 PostAuthor: Mr Bump » Tue Dec 06, 2022 7:05 am
I may have a good used one if you want it. I'll have a look this evening if you like.
Olly
Lemmy
Re: Gearbox Bearing
#8 PostAuthor: Z1streetfighter71 » Tue Dec 06, 2022 9:15 am
The full bearing set is £195 its worth the few extra pounds to be sound in the knowledge that whole area is sorted.
PhilMill63
Re: Gearbox Bearing
#9 PostAuthor: PhilMill63 » Tue Dec 06, 2022 3:46 pm
Thanks all, a whole new set sorted thanks to the great members of this club.
Phil
Users browsing this forum: No registered users and 142 guests
