Hi All, does anybody have pics to show the route of the wiring loom please? I did a search but cant find anything. I'm starting from scratch with a Z Power loom which I'm using on a US spec bike. I have bought switch gear and all the other loom parts so hopefully connecting it all will be relatively simple once I know how to route it.
Thanks, Phil
A4 Wiring loom routing
PhilMill63
- Regular Poster
'76 Z900A4, '76 Suzuki GT750, '83 RD350 Hybrid and too many projects!
Re: A4 Wiring loom routing
Try searching in the tech help section. Most things have been asked / discussed before.
viewtopic.php?f=4&t=46641&p=386955&hilit=wiring+loom+routing#p386955
colinKZ900B1
PhilMill63
- Regular Poster
kz900B1 wrote:Try searching in the tech help section. Most things have been asked / discussed before.
I looked again but still cant find anything, mind you, the search produces 21 pages which would take a week to go through all...the post you mention is for an ST, totally different than my A4.
Peteypops23
Phil,
I have a US spec A4 and the bodywork is away for painting so I could take some photos for you if you want? They won't be brilliant but they might give you an idea of routing.
PhilMill63
- Regular Poster
Peteypops23 wrote:Phil,
Hi Pete,
that would be great, thanks so much.
Phil
I would also be interested in this, as mines a US import and been apart before, so was done with tywraps not convinced its positioning was correct, as I've now had frame powder coated, would like to re fit loom correctly.
Any photos would greatly help.
Cheers guys
Cheers guys
- warren3200gt
If you got workshop manuals (if not why not!!!!) study each picture background regardless of chapter topic. The pictures will be period and from the factory so are undisputably as per they were factory fitted.
Peteypops23
Gray17 wrote:I would also be interested in this, as mines a US import and been apart before, so was done with tywraps not convinced its positioning was correct, as I've now had frame powder coated, would like to re fit loom correctly.
Cheers guys
PM sent mate.
Yes i do have 2 workshop manuals a Haynes and the official Z1, but as mines a later A4 it doesnt necesarily mean they are the same, plus most state refit in reverse of removal, no good if it wasnt fitted correctly after previous removal and refits by others over the past 40+ years. Hence request
PhilMill63
- Regular Poster
Gray17 wrote:Yes i do have 2 workshop manuals a Haynes and the official Z1, but as mines a later A4 it doesnt necesarily mean they are the same, plus most state refit in reverse of removal, no good if it wasnt fitted correctly after previous removal and refits by others over the past 40+ years. Hence request
Exactly what I came up against, thats why I asked on here, I hunted everywhere, luckily Pete helped with lost of pics for me.
