Caliper piston seal grove corrosion
Mrglee
#1 PostAuthor: Mrglee » Fri Mar 10, 2023 4:54 pm
I've got alot of corrosion in the piston seal grove's on all the calipers was going to use grit paper in various grades or is there a better way?.
BAFF1960
Re: Caliper piston seal grove corrosion
#2 PostAuthor: BAFF1960 » Fri Mar 10, 2023 5:07 pm
Hi.
I'd use a Dremel with one of those small diameter brass rotary wheels. Will not remove material but will the corrosion. Far less abrasive.
Alan
Brass wheel..jpg (27.18 KiB) Viewed 1326 times
Mrglee
#3 PostAuthor: Mrglee » Sun Mar 12, 2023 11:08 am
Cheers Alan just ordered a Dremel bit kit will give them a good clean out.
#4 PostAuthor: r3sc » Sun Mar 12, 2023 3:52 pm
I also use Alan’s method using the brass wire brush, however, make sure it is a brass brush as some of the cheaper ones have brass plated steel bristles which when abused, could damage the alloy of the calliper.
Cheers.
gray
#5 PostAuthor: gray » Sat Mar 25, 2023 8:20 pm
another option I've used is a 2mm ( I think ) Allen key, with the long end held in a set of Mole grips. It reaches round the corner at 90 degrees to the cylinder, and the accurately machined ends and edges will scrape the corrosion off the machined seal recess. do it gently and keep the long end parallel to the bore so it doesn't waggle back and forwards to gouge the alloy
gray
