Tacho needle wobble
Nobbyrobby
Tacho needle wobble
#1 PostAuthor: Nobbyrobby » Thu May 18, 2023 6:44 pm
Hi Guys.
I've got a problem with my Z1b's tacho. At idle it's pretty stable, but the more revs i put on, the wilder the 'swing'. Iv'e been told that the tacho mechanism is oil filled and this oil damps the needle's fluctuations? The oil apparently escapes over time causing the needle to oscillate. It's pretty annoying, especially next to the rock steady speedo needle. If this is the reason, can the mech be overhauled? If so, does anyone have a contact that they can pass on? Or am i potentially looking at another issue?
Wrigers
Re: Tacho needle wobble
#2 PostAuthor: Wrigers » Thu May 18, 2023 8:29 pm
Hi, Al Marshell is you're man for clock repairs, I've used him a few times and he's spot on.
http://z-clocks.co.uk/
Regards, Paul
Big Fluff
#3 PostAuthor: Big Fluff » Sun May 21, 2023 9:09 am
I take it you have already fitted a new tacho cable as this is the first place to look.
wilsonsjw11
#4 PostAuthor: wilsonsjw11 » Mon May 22, 2023 9:31 am
Invariably this will be caused the damping fluid within the unit drying out.
Regards
Steve
Nobbyrobby
#5 PostAuthor: Nobbyrobby » Wed May 24, 2023 6:48 am
Thanks very much all for the tips and info. I'm on it!
