Carbs
krbdude
Carbs
#1 PostAuthor: krbdude » Fri May 26, 2023 4:29 pm
Hi all , just purchaced some carbs listed as Z1000 26mm but when i measured the internal bore on the cylinder head end they are 26.8mm . Am i right in thinking they are 27mm .
Kind regards Keith
Re: Carbs
#2 PostAuthor: warren3200gt » Fri May 26, 2023 4:38 pm
They 26's. They need to be measured at the slide to get the correct dimension as they taper from the slide to the throat.
krbdude
Re: Carbs
#3 PostAuthor: krbdude » Fri May 26, 2023 5:58 pm
Cheers Warren . So they are 26mm but off what ?
code on mtg flange is 102
5A
main jet 115
pilot is 15 .... i think
Any help much appreciated .... cheers
Re: Carbs
#4 PostAuthor: warren3200gt » Fri May 26, 2023 6:29 pm
Fuel screw, air screw or both?
krbdude
Re: Carbs
#5 PostAuthor: krbdude » Fri May 26, 2023 6:32 pm
Only fuel screw underneath . I now believe they are off a KZ1000a2
https://www.ebay.com/itm/125556603675
Re: Carbs
#6 PostAuthor: warren3200gt » Fri May 26, 2023 6:36 pm
Sounds correct
krbdude
Re: Carbs
#7 PostAuthor: krbdude » Fri May 26, 2023 6:38 pm
Cheers for your help mate . So glad i can use them :D
Re: Carbs
#8 PostAuthor: kev edwards » Sat May 27, 2023 12:51 pm
If a2 they will have a vacuum stubb on number 3 carb.
Users browsing this forum: No registered users and 109 guests
