530 conversions
Katana
530 conversions
#1 PostAuthor: Katana » Sat Aug 26, 2023 7:04 pm
Hi have a Z1000r2 dose anyone know the sprocket numbers to do 530 conversion
Re: 530 conversions
#2 PostAuthor: chrisNI » Wed Aug 30, 2023 5:24 pm
What’s on it at the moment and is that gearing what you want?
Katana
Re: 530 conversions
#3 PostAuthor: Katana » Sat Sep 02, 2023 11:27 pm
It’s 630 at the moment n want std gearing
Re: 530 conversions
#4 PostAuthor: ADRIAN H » Sat Sep 23, 2023 5:01 pm
Kawasaki ZRX1200 - 2001 to 2004 chain and sprockets are 530, and has the same size spline for the front, and same diameter / spacings for the rear as a Z1000R. JT Sprockets list JTF1529 with a 16 or 17 teeth front sprocket. JTR488 with 38 - 47 teeth for rear sprocket.
Re: 530 conversions
#5 PostAuthor: chrisNI » Sun Sep 24, 2023 10:37 am
chrisNI wrote:What’s on it at the moment and is that gearing what you want?
Work it out with whatever front sprocket you’re going to use to get the same ratio as the stock setup. 530 sprocket usually a 17 tooth instead of 15 sums are pretty straightforward if you’ve not changed wheel sizes. 15/41 is 17/46 or 47 or 16/43 or 44
Re: 530 conversions
#6 PostAuthor: chrisNI » Sun Sep 24, 2023 11:00 am
ADRIAN H wrote:Kawasaki ZRX1200 - 2001 to 2004 chain and sprockets are 530, and has the same size spline for the front, and same diameter / spacings for the rear as a Z1000R. JT Sprockets list JTF1529 with a 16 or 17 teeth front sprocket. JTR488 with 38 - 47 teeth for rear sprocket.
You also need to make sure any front sprocket offset is taken into account I haven’t actually seen a standard R2 sprocket but I have a feeling it has a slight boss on the inside/back of it, the distance collar on the shaft finishes pretty much flush with the oil seal so if the 530 sprocket you get is completely flat you may need a spacer or a remade distance collar to line the front and rear sprockets up, as well as to clear the seal and casing.
