Static timing a Dyna S ignition
fusionpaul
#1 PostAuthor: fusionpaul » Wed Sep 04, 2013 5:33 pm
Just looking for a bit of advice on this dyna s ignition, according to the instructions when timing the engine statically it says connect a 12v test light from the junction of the black coil wires to ground. My black coil wires do not join at any junction they go separately to the ignition modules on the dyna s plate ?? Am i being stupid here, do i just connect test light to both coil wires & other end to earth ?? & with regard to advancing the rotor do i just turn it with my fingers whilst rotating the engine :?: :?:
#2 PostAuthor: chrisu » Wed Sep 04, 2013 5:40 pm
I did a how to on this subject
Do a search on my name and dyna
fusionpaul
#3 PostAuthor: fusionpaul » Wed Sep 04, 2013 6:11 pm
chrisu wrote:I did a how to on this subject
wish i'd seen that before :) she sounds spot on now at idle & at 3-4000rpm but suppose the only way to tell is take it out for a run
thanks, Paul.
Garn 1
#4 PostAuthor: Garn 1 » Fri Sep 06, 2013 8:34 pm
Chrisu, how about a "link" to your posting.
I am interested in what you had to say!
#5 PostAuthor: z1bman » Fri Sep 06, 2013 9:38 pm
you must use the black + the green wires that go directly to the coils to do this test + yes you must turn the advancer fully clockwise with your fingers whilst turning the crankshaft to check it statically
RAYZ1
timing
#6 PostAuthor: RAYZ1 » Fri Sep 06, 2013 10:29 pm
As Im away to do this as well, can it not be done with a strobe ?
Garn 1
#7 PostAuthor: Garn 1 » Fri Sep 06, 2013 10:31 pm
Thanks Z1bman, I wanted to check out what Chrisu has to say about that facet of the static adjustment.
To my mind, by adjusting with the rotor falsely moved to the advanced position, I can't understand why it wouldn't effect the timing at idle.
I always check dynamically with a timing light and have always disliked that static method.
fusionpaul
#8 PostAuthor: fusionpaul » Sat Sep 07, 2013 4:42 am
Here's a link to the post
http://www.z1ownersclub.co.uk/forum/vie ... ght=#22551
thought i'd set it up right, should have put the instructions that came with the kit in the bin first, read christu's post a few times & did it again his way & now its running much better :)
#9 PostAuthor: z1bman » Sat Sep 07, 2013 9:16 am
the instructions are a bit misleading to some. you either follow one procedure or the other i/e static if you don't have a strobe light this is why you have to hold the cam in the full advance position. if you have a strobe light skip to the strobe light section of the timing instructions
Garn 1
#10 PostAuthor: Garn 1 » Sat Sep 07, 2013 9:25 am
Thanks for the link fusionPaul, thanks again Z1bman.
ExSpeedTripleOwner
Re: Static timing a Dyna S ignition
#11 PostAuthor: ExSpeedTripleOwner » Wed Mar 05, 2025 4:43 pm
I am trying to time the Dyna S on my Z1, I found this post but the link does not work. Can someone post the instructions again?
kz900B1
#12 PostAuthor: kz900B1 » Wed Mar 05, 2025 5:46 pm
Hi .
Here's the link below I believ. As its in the HOW to section you have to be a PUM to view.
viewtopic.php?f=22&t=2588
colinKZ900B1
#13 PostAuthor: warren3200gt » Wed Mar 05, 2025 6:06 pm
I've always found it simplest and most accurate to set them up using a circuit tester and on the F mark and static engine.
Elimanates the any variables with spring strength etc.
Then check it with a strobe afterwards.
PUM 488 June 2023
gray
#14 PostAuthor: gray » Wed Mar 05, 2025 7:09 pm
yes static timing gets it in the ball park so at least it runs, then once its running then strobing gets it spot on.
gray
KeithZ1R
#15 PostAuthor: KeithZ1R » Thu Mar 06, 2025 3:00 pm
This is how I do it Dyna
all plugs out turn engine to 1.4 F mark … put a plug in lead from1 / 4 coil were you can see it earthed on the engine , turn the ignition on twist the dyna trigger as far as it will go clockwise, then while holding it There move the carrier plate until you see / hear a spark on the plug you positioned carefully. tighten everything up and run it , you can check with a strobe later ,
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
