Z1-B Front fork clean
steve452
#1 PostAuthor: steve452 » Mon Mar 10, 2025 5:31 pm
Can any of you kind folk confirm that I have the correct sequence of bits on this Jan 1975 build Z1-B fork damper (I believe it's a 44022-028).
Also, what's the current thinking on the best oil to use in the forks. Manual just says 170ml of SAE10. I know this has been discussed before but the last reference I can find on the forum is from 10 years ago.
Z1-B, 360bhp ZX1000NGF
wheelysteve
Re: Z1-B Front fork clean
#2 PostAuthor: wheelysteve » Mon Mar 10, 2025 7:38 pm
Here are mine also from Early 75 Z1B
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Paul Spencer
#3 PostAuthor: Paul Spencer » Mon Mar 10, 2025 7:43 pm
Having recently re-built my Z1B forks, I think you've got it right.
steve452
#4 PostAuthor: steve452 » Wed Mar 12, 2025 3:31 pm
Further to the above I cannot for the life of me find the torque setting for the damper cylinder bolt (44041-040). It's an M10 Allen bolt. It's not listed as a specific bolt in the shop manual and in the general torque settings M10 bolts are listed as having 1.25mm pitch in the "Fine" category. The damper bolt is 1.00mm pitch. Looking at the InterWeb indicates that finer pitch requires lower torque for the same preload.
Can anyone offer any help? TIA.
