Fuel hose.
ianali
Fuel hose.
#1 PostAuthor: ianali » Mon Mar 31, 2025 1:31 pm
What is recommended for replacing the short hose from fuel tap to carbs? Am I right that it’s 8mm? Mine has perished I think partly due to it being such a tight bend. Is there something a little more flexible ?
Ian.
Re: Fuel hose.
#2 PostAuthor: warren3200gt » Mon Mar 31, 2025 1:37 pm
Re: Fuel hose.
#3 PostAuthor: ADRIAN H » Tue Apr 01, 2025 8:14 pm
ianali wrote:What is recommended for replacing the short hose from fuel tap to carbs? Am I right that it’s 8mm? Mine has perished I think partly due to it being such a tight bend. Is there something a little more flexible ?
Ian.
Internal diameter is 6.4mm or 1/4 inch. Just a thought, you could fit a flex stainless steel spring over the fuel line to get around the bend.
gray
Re: Fuel hose.
#4 PostAuthor: gray » Wed Apr 02, 2025 7:06 pm
make sure its resistant to ethanol in petrol - I have a notion that it should have a "J" as part of the code number on the side. (If I've got that letter wrong feel free to correct me)
gray
Re: Fuel hose.
#5 PostAuthor: kev edwards » Thu Apr 03, 2025 6:22 pm
If you are not worried by non original looks, go for tygon, it's clear yellow but you have to have wire spring around it as it has a tendency to kink, I use it on mine.
Mark Tiller
Re: Fuel hose.
#6 PostAuthor: Mark Tiller » Thu Apr 03, 2025 6:52 pm
APE do fuel filters https://www.amazon.com/Inline-Fuel-Filt ... 192&sr=8-6 which will help.
search for pipe thats OK for E10 fuel
07962421462
Users browsing this forum: No registered users and 330 guests
