Hi,
Due to a drip, i took off my fuel tap on my a4. After removal i found a demolished rubber seal or o ring in the big nut that screws onto the tank. There is a groove inside the nut for the seal. Does anyone know the diameter of this seal? It is beyond measuring. Thanks Tommy
fuel tap rubber seal/oring
Re: fuel tap rubber seal/oring
Can't tell you size but is this the part you need? Relatively cheap and available.
https://www.cmsnl.com/products/gasket-f ... _92065081/
Thanks John.
wilsonsjw11
The required rubber seal is a stock item at Z-Power.
Regards
Steve
Regards
Steve
don't be tempted to use an o ring that's the right size. the seal has flat surfaces top and bottom where it presses against tank flange and tap face flange
gray
thanks Gray i was indeed tempted to use a O ring, but got the right flat one instead. Now i have unscrewed the bowl and a piece of hard rubber came down:seal completely goosed. Could i try a ordinary O ring in there? or is it a shaped seal? Tommy
I think that's a round section O ring ( but I'm sure I will be corrected if wrong)
gray
