Head Gaskets
Barnett
Re: Head Gaskets
#16 PostAuthor: Barnett » Sat May 31, 2025 2:52 pm
Vesrah has always been my go to choice when genuine not avail or expensive. I was told years ago they make the oem gaskets for all the manufacturers. I never have problems with them, that said of late the valve stem seals included in the kits are rubbish and I suspect they buy these in. Difficult to find but they do pop up, IMD Pistons did them sometimes, have bought from France and Germany before but if you look now Z power have some!
Big Fluff
Re: Head Gaskets
#17 PostAuthor: Big Fluff » Sun Jun 01, 2025 8:27 pm
Yes, what an impatient individual indeed.
One of the best forums ever this, with hundreds of years of accumulative knowledge.
Adrianbrooksbank
Re: Head Gaskets
#18 PostAuthor: Adrianbrooksbank » Mon Jun 02, 2025 12:40 pm
Put head gaskets and pattern o rings on my Z900A4 and is perfect plus just replaced cam chain tensioner and spring supplied by Zpower and again is perfect. Made sure head was level and replaced due to 20years the o ring was failing plus weeping from ends,always had same problems on all 4 cylinders air cooled,Hope this helps
