Brakes
stusco
Brakes
#1 PostAuthor: stusco » Thu Aug 07, 2025 2:57 pm
So ive got zrx1200 daeg forks on my gpz1100 i got a nice top yoke made to take the ignition and clocks now im onto wheels and brakes,ive got zrx1200 wheels new discs now im looking for calipers preferably Brembo but it turns out the mount holes are 63mm and there are very little brakes out there ! Would you open out the mount holes to take 65mm brake as there is a wide selection?
Re: Brakes
#2 PostAuthor: warren3200gt » Thu Aug 07, 2025 6:53 pm
Make adapter plates
gray
Re: Brakes
#3 PostAuthor: gray » Thu Aug 07, 2025 9:47 pm
Agreed - bit dodgy to oval out the holes to fit, you'll create a weak spot and then one day , on heavy braking ,the calliper will come adrift just when you need it to be rock solid
gray
stusco
Re: Brakes
#4 PostAuthor: stusco » Sat Aug 09, 2025 2:33 pm
warren3200gt wrote:Make adapter plates
Do you know anyone that makes adapters?
Re: Brakes
#5 PostAuthor: warren3200gt » Sat Aug 09, 2025 3:03 pm
Pretty much any engineering workshop can make them if you can't yourself. Just need to give them drawings.
FER
Auld Heedyun
Re: Brakes
#6 PostAuthor: FER » Sat Aug 09, 2025 5:14 pm
Rapide Engineering , Trinty Gask , Auchterarder . 01764 683853 . They made the plates for the brakes on the front of our 1000R2 , std forks , Eliminator wheel , 320mm floating discs and Nissin 4 pot calipers . I am taking the front end from my klr650 up over the winter to get a plate made to for a brake upgrade .
fer
stusco
Re: Brakes
#7 PostAuthor: stusco » Mon Aug 11, 2025 5:27 pm
FER wrote:Rapide Engineering , Trinty Gask , Auchterarder . 01764 683853 . They made the plates for the brakes on the front of our 1000R2 , std forks , Eliminator wheel , 320mm floating discs and Nissin 4 pot calipers . I am taking the front end from my klr650 up over the winter to get a plate made to for a brake upgrade .
fer
Cheers not too far away either
Re: Brakes
#8 PostAuthor: Z1streetfighter71 » Mon Aug 11, 2025 5:51 pm
https://biketorquetrade.co.uk/product/b ... um-finish/
Re: Brakes
#9 PostAuthor: Z1streetfighter71 » Mon Aug 11, 2025 5:55 pm
Not to be pedantic but why? the zrx1200 calipers are more than adequate and the Brembo set up is around £722.00
https://www.ebay.co.uk/itm/134743109419
stusco
Re: Brakes
#10 PostAuthor: stusco » Sat Aug 16, 2025 12:34 pm
Z1streetfighter71 wrote:Not to be pedantic but why? the zrx1200 calipers are more than adequate and the Brembo set up is around £722.00
That set up doesn’t fit the forks i have ,and bike torque don’t do adapters for my forks , i got brembo callipers for half that price from japan .
Next question is do i need the brake disc gaskets? I’ve never seen them before bit the zrx1200 has them.
stusco
Re: Brakes
#11 PostAuthor: stusco » Sat Aug 16, 2025 7:14 pm
I don’t like tokio callipers they are prone to seized pistons
KWACKERZ1
Re: Brakes
#12 PostAuthor: KWACKERZ1 » Tue Aug 26, 2025 8:29 am
Hi Nissin 4 pots from gsxrs etc are brilliant and bolt straight on.
Alternatively you couldgo radial as Hel do brackets to convert to radial.
stusco
Re: Brakes
#13 PostAuthor: stusco » Tue Aug 26, 2025 5:20 pm
My forks are zrx1200 daeg they are different from the uk zrx1200 forks
