Z1000st
Foxy1057
Z1000st
#1 PostAuthor: Foxy1057 » Fri Dec 05, 2025 3:30 pm
Hi all
Does anybody know what causes the rev to not drop as quick as they should? When I blip the throttle it’s sometimes slow to come back down to idle !
Any help would be much appreciated.(1979z1000st)
KevH
Re: Z1000st
#2 PostAuthor: KevH » Fri Dec 05, 2025 4:44 pm
Possibly cracked rubbers between carbs and head. Is the throttle snapping shut all the way.
Speedie
Re: Z1000st
#3 PostAuthor: Speedie » Fri Dec 05, 2025 6:08 pm
Blocked pilot jets are typical. I always drain my carbs after every run as I never know when I'm going out next on the bike. Ethanol, say no more.
Paul
Foxfix
Re: Z1000st
#4 PostAuthor: Foxfix » Sat Dec 06, 2025 9:04 am
Mixture settings. Use a Gunston Colortune Plug to set.
Synchronization. Use vacuum gauges.
Choke Plunger Rubbers. Have them replaced with Viton type.
Grog
Re: Z1000st
#5 PostAuthor: Grog » Sat Dec 06, 2025 10:15 am
Hello mate;
Had something similar on mine after a carb rebuild. Turned out to be lean running, a bit of tweaking of the air screws sorted out the idle mixture and cured the problem. (79 Z1R in this case).
TTFN Grog
1979 Z1R (mostly - it's been fiddled with a bit)
1977 Z650B1 - I'll get round to putting it back together one day...
Foxy1057
Re: Z1000st
#6 PostAuthor: Foxy1057 » Sat Dec 06, 2025 10:43 am
Thanks for all the replies, the bike has just had the carbs rebuilt , so maybe a bit of fine tuning , is there a way of setting tgg HD e air screws without gauges? Ie so many turns out ?
redzee
Re: Z1000st
#7 PostAuthor: redzee » Sat Dec 06, 2025 10:55 am
Binding or incorrectly routed throttle cable?
Eight valve grunt.
Mark W
Re: Z1000st
#8 PostAuthor: Mark W » Sat Dec 06, 2025 12:38 pm
Found the same thing with incorrectly adjusted throttle cables
Grog
Re: Z1000st
#9 PostAuthor: Grog » Sun Dec 07, 2025 10:23 am
Assuming the throttle cables are free running and there are no air leaks, there's a decent chance the carbs just need setting up after the rebuild (which fingers crossed should also mean the pilot jets are in decent nick). I think the ST has 28mm carbs, yes? In which case, turn the air screws fully in and then back them out one and a half turns as a good starting point, see if that helps. The further out you back the screws the leaner the mixture, so if the problem persists try turning them back in an eighth of a turn at a time, see if that cures it. Without gauges it's a bit 'finger in the air' for accuracy but hopefully it'll tune out the hanging problem.
TTFN Grog
gray
Re: Z1000st
#10 PostAuthor: gray » Mon Dec 08, 2025 8:10 pm
if the carb to head rubbers are drawing air and causing the revs to hang when you shut off, you can check by spraying a but of easy start around the rubbers when the engine's idling. If the revs rise as you spray 1 rubber, its leaking
gray
