Z1000a2 Carb T piece
A1John
#1 PostAuthor: A1John » Thu Jan 22, 2026 11:32 am
Hi, can anyone please tell me if the carbs have O rings on the T piece on a 78 z1000a2 ? if they do how many? thanks.
Re: Z1000a2 Carb T piece
#2 PostAuthor: warren3200gt » Thu Jan 22, 2026 11:42 am
Mikuni had changed to sleeves by then.
If you can't find new sleeves take the old ones off, wrap some ptfe tape around the spigot to increase the diameter then refit the sleeve.
KeithZ1R
#3 PostAuthor: KeithZ1R » Thu Jan 22, 2026 9:07 pm
cut the old sleeves off thus :-
then replace with :-
https://www.ebay.co.uk/itm/260675687317
thus
I had to run the o/d down a smidge to facilitate pushing into the carb bodies after sliding onto the Tee , I achieved this in the lathe however a drill chuck and some fine emery cloth would do just as well I have had similar success with the straight pieces but they tend to be easier as they are normally a brass tube, for info I did this in 2020 they are still holding fine on all 4 bikes I still own but have actually done it on about 7 sets of carbs , just a possible solution that you can try or not :) :!:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Users browsing this forum: No registered users and 98 guests
