Battery box Gpz1100
Taffus
Battery box Gpz1100
#1 PostAuthor: Taffus » Mon May 19, 2008 5:54 pm
took the seat off for the first time today and found the battery loose in the battery box. Also the mounting lug for LHS electrical plate was rusted through.
Made a temporary repair and tie wrapped the battery in.
My question is should there be a clamp on the RHS to hold the battery in place ?
I think there should be as there is no hole for the bottom lug of the side panel to fit into (I can't see any evidence of any welds broken off the frame in this area)
TIA
Mark
london calling
#2 PostAuthor: london calling » Mon May 19, 2008 8:56 pm
Have a word with Steve "Full Monty" Cundall,he'll be able to help you.
He can even spell GPz :wink: :wink:
Jack
big green bus
bracket
#3 PostAuthor: big green bus » Mon May 19, 2008 11:17 pm
yes there is a bracket that holds that battery and the side panel in place i will post a pic later. sorry i do not have a one spare.
Robw
#4 PostAuthor: Robw » Tue May 20, 2008 7:17 am
Taffus, is this what you are after, this is a picture of my Z1000R, which has a bracket on the RHS with a grommet for the side panel.
Rob
Sorry the photo is not that good if you need one from the side, just let me know.
london calling
#5 PostAuthor: london calling » Tue May 20, 2008 8:53 am
The GPz battery box is different to the 1000J,smaller battery,etc.
Jack
Taffus
#6 PostAuthor: Taffus » Tue May 20, 2008 9:35 am
hi
its got a huge battery in there at the moment, I have tie wrapped it down (with an even huger tie wrap), Bit worried about losing the side panel (happened on my CB900F, took ages to get another)
I 'll get the photos done tonight
