Hi, this is my first question to the group. When I bought my Z1B back in 1978 it came fitted with this drainer, obviously the first owner spent some time making this bit, but is it of any use, or just dead weight? It fits to the breather pipe work and then goes back into the bottom of the air box. Should I just leave it off? Any help appreciated.
Mart
[/imghttp://s478.photobucket.com/albums/rr147/durhamz1b/?action=view¤t=IMG_0101.jpg[img]
[/imghttp://s478.photobucket.com/albums/rr147/durhamz1b/?action=view¤t=IMG_0102.jpg
Breather Drain?
Baz Swailes
Durham/Yorkshire
Hi, originally from a place called Chopwell, north of Durham, it was in County Durham when I was born but now in Tyne and Wear. I just live in South Yorkshire and have done for a long time.
Mart
Mart
I thought as much. It had been painted to the same quality as the rest of the black parts and I wasn't sure if it was a standard bit when I first got the bike. It was only when I stripped the bike that I found out it was brass and copper.
Thanks Fer
Mart
Thanks Fer
Mart
FER wrote:Looks like it was made to catch the oil and moisture that comes out of the engine and is normally just fed back through the air box . The bike should run ok without it . Really only need something like this if you junk the air box and want to stop the crap going over the back tyre .
fer
the breather pipe on mine exits just over the chain........
Steve Cooke
- ZedHead
