G'day all,
Regarding the above bracket on a 900-A4. Is it the same as the one on the Z1's? The only one I've seen on an A4, had a slotted end on it (for adjustment?) but the one pictured for the Z1 looks a tad different.
Also would a warning sticker set for a Z2 be more or less the same as the A4's?
Any thoughts?
Headlight stabilising bracket and warning stickers
Begging your pardon sir, but you did say that you'd like .................a green one?
Sorf, regarding that headlight stabiliser bracket, I think it's the same for all Z1 series. However, the Z1000 1A has a different one, I think it's similar to the Z650 bracket. Can't be sure with the A4, maybe they didn't have one!
Regarding Warning Sticers ~ I understand the Z2 came out in both types of frames. Firstly with the ones identical to the Z1 series, then with a frame as the Z900-A4. They would have been a difference in the under-seat sticker (battery drain-tube configuration) on these later models.
RegardZ
RegardZ
- rickman CRR
Thanks,
Garn, from what you're saying, if the later Z2's came out with a frame as per the 900-A4, then wouldn't the battery drain be the same? (or not).
Rickman, I'm sure you're right! I just realised what both Garn and TPR had said on another forum. Geez, the old memory is struggling.
So OK, no bracket for the A4.
