Valve Clearances
bollypne
Valve Clearances
#1 PostAuthor: bollypne » Wed Mar 25, 2009 7:54 pm
Hi all
Z900 A4. Decided to check valve clearances due to poor running and curiousity. According to the book, clymer. clearances should be 0.05-0.10mm. On checking every valve i can't even slip under a 0.04 mm feeler. So obviously all shims need doing, grrr. And i need a shimming tool. I'm in Leyland if anyone near can lend advise.
Advice please.
thanks lads.
Colm
Big Bol
Z900, ZRX1200r & a Z900rs Cafe
jacobmarley
Valve clearances
#2 PostAuthor: jacobmarley » Wed Mar 25, 2009 8:34 pm
Try Gerry the Chairman, he manages a shim swop system, he may also have a shim removal tool you can rent or borrow? The shim swop system worked great when I used it.
bollypne
#3 PostAuthor: bollypne » Wed Mar 25, 2009 8:44 pm
Thanks, does Gerry have a differnet username on the forum?
Big Bol
#4 PostAuthor: Pigford » Wed Mar 25, 2009 8:55 pm
YES.....
JERRY with a J
:wink:
phil churchett
#5 PostAuthor: phil churchett » Wed Mar 25, 2009 9:00 pm
Jerry Humpage, his number is in the club magazine.
bollypne
#6 PostAuthor: bollypne » Wed Mar 25, 2009 9:14 pm
cheers.
Big Bol
JohnC
Re: Valve Clearances
#7 PostAuthor: JohnC » Wed Mar 25, 2009 9:21 pm
bollypne wrote:Hi all
Advice please.
thanks lads.
Colm
Not that expensive tbo, £20 from Z-power new. If I remember many folk (Debben etc) recommend running much larger clearances than the manual suggests.
cra-z1
#8 PostAuthor: cra-z1 » Fri Mar 27, 2009 3:18 am
Bite the bullet and buy a shim tool. Once you find out what shims you have under the valves, you may be able to swap them around to get the tolerances right. You will need at least one to start the process. Will probably only need a couple a sizes in the end. Then make a log of what you have under what valve. The next time you measure you will know what will be need to correct.
bollypne
#9 PostAuthor: bollypne » Fri Mar 27, 2009 7:44 am
Cheers, a tool has been ordered. Got to come in handy and any one in my area can borrow, for the cost of a beer!
Big Bol
Users browsing this forum: No registered users and 96 guests
