Won't fire up
Won't fire up
Evenin all, tried starting the ST earlier to do an oil and filter change but it won't start. Battery has plenty of power, starter motor spins, plugs are only a few weeks old, fuel tap working, plenty of fuel, carbs have fuel, no apparent blockages...Manual says could be defective starter motor clutch or a loose alternator rotor bolt, would either of these sound likely? Is this common? Was running fine just days ago, has always started 1st or 2nd go. Not sure what else it might be, any help much appreciated.
1979 Z1000ST
She lives! Now I'm not sure how but I tried to start it normally again without success. I took the tank off to test spark, held plug to the block and pressed starter, spark was fine and it sounded like it fired. Did the same with a different plug, same response. Put tank back on and 2nd try she spluttered into life. Thats after a good 20 mins without a hint of life so I've no idea why this made a difference. Main thing is I'm back in business. Thanks for all your help though, overwhelmed by responses/pm's/emails. Brilliant stuff!
1979 Z1000ST
tedsonthezed
Users browsing this forum: Foxfix and 33 guests
