IRIDIUM SPARKERS - Worth the money?....
MaineKZ
#1 PostAuthor: MaineKZ » Thu May 21, 2009 11:49 am
Anyone running Iridium plugs? Are they worth the dosh or load of old hype?...
zeroed
#2 PostAuthor: zeroed » Thu May 21, 2009 12:29 pm
Pleased with mine, not expensive paid approx £30 for a set. supposed to last 50k +
http://www.spark-plugs.co.uk/
zince
#3 PostAuthor: zince » Thu May 21, 2009 3:22 pm
Pleased with mine too , instant starting on my 72 and noticably better than running standards as I do on the others .
Worth it I think !
HD/GS/Z1/Z900RS/ Norton
#4 PostAuthor: Pigford » Thu May 21, 2009 8:48 pm
Had 'em in me Black Z1000 for a year now.... no probs.... May be OTT for a standard set up (points etc) but ......peace of mind :P
Reecy
iridium plugs
#5 PostAuthor: Reecy » Thu May 21, 2009 9:55 pm
Oh yes these are definately worth getting
My zeds have them and starting which was a bit of a lottery previously became much more certain and my Z1000A2 starts and feels like a new bike
got to get yourself some.
Reecy
zedrider
#6 PostAuthor: zedrider » Thu May 28, 2009 9:17 pm
my first thoughts were HOw much ? but now there fitted yes they good and well worth ago .
zed
AL MARSHALL
plugs
#7 PostAuthor: AL MARSHALL » Fri May 29, 2009 1:17 pm
:cry: having trouble working the sparkplug.co.uk website. can anyone tell me the correct iridium plug type for z1 and z650 b1 :?:
trouble.......seek and ye shall find
www.z-clocks.co.uk
steve bowdler
#8 PostAuthor: steve bowdler » Fri May 29, 2009 1:37 pm
Al try this
BR7EIX Iridium £5,89
B7EVX Platinum £5.75
MaineKZ
#9 PostAuthor: MaineKZ » Fri May 29, 2009 7:14 pm
Shoved a set in a day or so ago - difference is noticeable particularly on start up and at low revs - very nice.
The Z1 takes BR8s not 7s - so says the NGK plug finder anyhow
All in all - worthwhile
AL MARSHALL
ploogs
#10 PostAuthor: AL MARSHALL » Fri May 29, 2009 7:25 pm
cheers steve thats just what i needed to know :D
www.z-clocks.co.uk
zeroed
#11 PostAuthor: zeroed » Fri May 29, 2009 7:39 pm
standard z1/za/zb/z900a4 z1000/a1/a2/a3/a4 z1-r
shows B8ES, Platinum B8EVX, Iridium BR8EIX (NGK)
J2/J3 /LTD showing same
£1.60 st £5.75 plat £5.89 Ir + pp (coupla quid)
lta01
#12 PostAuthor: lta01 » Fri May 29, 2009 10:04 pm
I've tried both NGK and Denso iridiums, both are a noticeable benefit, but on one of my bikes ( not a Zed ) , I've found that the Densos are markedly better at igniting less than perfect mixtures.
One word of warning, Iridiums, especially with Dyna coils, are almost capable of igniting fresh air :D ..... you can have a very ( too ) lean mixture and you don't get the typical hesitation symptoms, until its a bit too late.. :oops:
So even though they burn clean and are supposed to last for 10's of thousands of miles, still make a habit of checking the colour once in a while.
He who dies with the most toys wins .
bigmac103
#13 PostAuthor: bigmac103 » Sat May 30, 2009 6:30 pm
I've used iridium's on a bike with worn piston rings and I found trouble with starting due to fouling the number 2 plug. Once I got it going they were noticeably different especially at low rpm/speeds. I changed to iridium's on a my Z1A which as recently had work done so no piston ring issue and I wouldn't use anything else now, really smooth.
Lost in the desert somewhere
Users browsing this forum: sockpuppet, wyrmat1 and 55 guests
