wheel swap
northman
wheel swap
#1 PostAuthor: northman » Thu Jun 11, 2009 11:26 pm
Do any of you knowledgeable guys know if the sprocket carrier/cush drive from a Z1R can fit a 1000mk2 (i.e are the back wheels the same)?
Thank you!
Northman
NORTHMAN
Gus
#2 PostAuthor: Gus » Fri Jun 12, 2009 7:48 am
These have the same wheel assemblies
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-D1 (Z1R) (1978)
KZ1000-D3 (Z1R) (1980)
"Set the GRINDER on it"
northman
#3 PostAuthor: northman » Fri Jun 12, 2009 3:54 pm
Cheers Gus, just the job!
NORTHMAN
BShaw
#4 PostAuthor: BShaw » Sun Jun 14, 2009 9:02 pm
Steve, can't pm you for some reason. but I have a sprocket carrier, 33 tooth sprocket and cush drive for you, can't see part numbers on it but its from a Z1r wheel
Regards
Baza
northman
wheel swop
#5 PostAuthor: northman » Mon Jun 15, 2009 1:13 pm
Excellent Barry-PM sent
NORTHMAN
