Electrical Kill Switch Help
This is from the diagram supplied, e&oe .Join the 2 black wires as this will complete the circuit for the starter motor solenoid.
Leave the other wires disconnected as this allows the coils to be earthed and will stop the engine if both the clutch is not pulled in and the side stand is down.
Leaving them disconnected stops you needing to pull the clutch in to start but will allow you start in gear so be careful! You could join them and pull the clutch in to start.......I hate that though its a pain in the arse.
Royalratch
Royalratch
Users browsing this forum: No registered users and 84 guests
