Steering Damper
Z1000ELR
Steering Damper
#1 PostAuthor: Z1000ELR » Mon Aug 03, 2009 6:29 pm
Right chaps just bought this: http://www.busters-accessories.co.uk/pr ... saki-Style
Thinking it would bolt straight on...it doesnt!! I have a mark 2 or Z1R frame. Anybody help with how i fit it please??
Si
tlc
#2 PostAuthor: tlc » Mon Aug 03, 2009 6:32 pm
What size are your forks ?
I have a clamp assembly.
Z1000ELR
#3 PostAuthor: Z1000ELR » Mon Aug 03, 2009 6:40 pm
Ill check and let you know mate. Thanks
Z1000ELR
#4 PostAuthor: Z1000ELR » Mon Aug 03, 2009 6:44 pm
Tailift,
38mm mate
Si
tlc
#5 PostAuthor: tlc » Mon Aug 03, 2009 8:13 pm
37.6mm :D
Z1000ELR
#6 PostAuthor: Z1000ELR » Mon Aug 03, 2009 9:29 pm
Smarty pants!!!
You have a PM mate
Z1000ELR
#7 PostAuthor: Z1000ELR » Wed Aug 05, 2009 3:45 pm
Right then,
Fork clamp sorted, still have to attach it at the frame end!
Can anybody help please?
Si
Gus
#8 PostAuthor: Gus » Wed Aug 05, 2009 4:03 pm
Isn't it supposed to connect between the front down tube angle bracket and the bottom yoke?
"Set the GRINDER on it"
Z1000ELR
#9 PostAuthor: Z1000ELR » Wed Aug 05, 2009 4:10 pm
Gus
But where to attach it mate (frame end)
#10 PostAuthor: Pigford » Wed Aug 05, 2009 5:38 pm
If there is no hole on the lower headstock area (often r/h side) you'll have to find a suitable place, that allows full left-right stroke of the damper... Then drill holes to fix a suitable bracket :wink:
#11 PostAuthor: Al » Wed Aug 05, 2009 7:43 pm
Just to give you a very rough idea of what may be required, this is the Damper assy from the 'J' with its brackets and other bits attached.
This is where it was fitted on the right H/S before i took it off.
There are two captive nuts on the frame gusset plate on mine but dont know if they are original as the damper was fitted when i got the bike.
The arc of the damper rod ran very very close to the cam cover if i remember and the damper body is not that far from the tank.
Quite a difficult juggling act for the previous owner but it was managed. Just!!
Z1000ELR
#12 PostAuthor: Z1000ELR » Wed Aug 05, 2009 7:48 pm
Al,
Thats the one. Its the small oval bracket i need to get then. Any ideas where?
If not ill get one made
Si
#13 PostAuthor: Al » Wed Aug 05, 2009 7:58 pm
Not really just now except the wants section.
I can bring it with me on Saturday and you could get it copied if its exactly the same as you need which i cant guarantee.
Users browsing this forum: No registered users and 84 guests
