Hi guys.
Having ran out of petrol I decided it was a good opportunity to take the tap off, check tank for crud etc.
I was surprised to see the tap di not have any brass pipes attached to the internal. I remember they should have at least one higher than than the other inlet for the reserve function.
Assuming my memory/logic is correct, can you get the pipe from anywhere or is it a new tap from Z-power??
Many thanks
Colin
Vacuum petrol tap - main/reserve inlet question.
- colin.carter
- Regular Poster
- colin.carter
- Regular Poster
Yep indeedy, should have a tall plastic pipe assembly with an oval shape which fits tightly into the tap, it consists of two plastic pipes, (tall and short) inside an oval plastic frame with fine mesh to filter crud, the tall (main or on) goes to the centre hole the short one (res) to the offcentre.
Check your tank, it's not uncommon for them to work loose and be rattling about inside there, I had the same happen to a ZZR250 I had some years ago.
If not I think you can buy the filter on it's own?
- colin.carter
- Regular Poster
- colin.carter
- Regular Poster
Users browsing this forum: No registered users and 82 guests
