Re: Front brake problem
Posted: Tue Apr 02, 2024 4:01 pm
Thanks Philippe. The brakes are fine now, it was the blocked hole. When the brake is applied the calipers are solid, when released have a little bit of wobble, so all good. I do need to get a front lever though as the ball is missing. Will bear in mind what you've mentioned, Cheers
