Repro Loom Ignition 6pin connector
PAULJAC47
#1 PostAuthor: PAULJAC47 » Wed Jan 27, 2010 5:40 pm
Hi All just finishing installing my repro loom have noticed that the loom has a 6 pin input for the ignition switch 4 pins, the top 4 colours match but 2 pins are left empty,checked a mates original on his z1 and both ends are 4 pin! any one else noticed this? what are the two extra wires for in the loom?
Any input welcomed on this....Paul J..
Garn 1
#2 PostAuthor: Garn 1 » Wed Jan 27, 2010 6:30 pm
PaulJac, I think you will find you have a Z1000 harness. It still may surfice though. Those extra wires are for that useless hazard relay. Check to see if there is provision on the harness for the (z1000/ z900) three-fuses box at the control panel. Also check the harness connector for the LHS switch block. That is probably a 6 pin connector too.
It may be "one harness fits all" combo, otherwise I would return and get a Z1 series replacement.
RegardZ.
PAULJAC47
#3 PostAuthor: PAULJAC47 » Wed Jan 27, 2010 6:42 pm
Thanks Garn1 it is supposed to be a direct z1b replacement i got from the states everything else seem to tie up,it is the sinlge fuse type,will juice it up and see what works and what does not,Thanks Paul j...
GEZ635
#4 PostAuthor: GEZ635 » Thu Jan 28, 2010 2:32 pm
The repro looms use the 6 pin but it will work ok with your 4 pin. Gez
Gez
PAULJAC47
#5 PostAuthor: PAULJAC47 » Thu Jan 28, 2010 5:21 pm
Thanks GEZ,bike is coming along well since you last saw it should not be too long b4 i get her going,Cheers Paul J..
PAULJAC47
#6 PostAuthor: PAULJAC47 » Thu Jan 28, 2010 9:14 pm
All wired up now and working even the outage relay!!!!
GEZ635
#7 PostAuthor: GEZ635 » Thu Jan 28, 2010 10:40 pm
should be over at Pauls on saturday so I will pop round if you are in .
Gez
Gez
