Tips for fitting Z650 centre stand spring please?
pertonpc
#1 PostAuthor: pertonpc » Wed Feb 03, 2010 7:55 pm
Hi Folks,
Expecting main stand back from coating next week - spring was dead tight to get off and I'm keen not to damage the stand or frame repaint when it goes back on. Anyone done this recently and worked out a good method - the 650 has a long spindle that goes through both sides of the stand from the same side as the spring which fits down the side of the stand.
Thought about prising some dowel between coils of the spring to open it a bit - could a big G clamp be adapted into a spring puller? Any ideas or pics of how you've done it would be most welcome. From Mark in Staffs.
kas750
#2 PostAuthor: kas750 » Wed Feb 03, 2010 8:21 pm
irhobotolo
#3 PostAuthor: irhobotolo » Wed Feb 03, 2010 8:26 pm
kas750 wrote:This works like a charm.. :D
http://kawtriple.com/mraxl/tips/centers ... spring.htm
Yep. Absolutely the only way to get both the side and centre stand springs back on is to bend the spring backwards and forwards loading it with washers until its lengthened considerably. :shock:
#4 PostAuthor: Ginger Bear » Wed Feb 03, 2010 8:38 pm
What a top tip, What a top site.................. Thankyou guys, I've learnt something new (and useful) today. :lon
kas750
#5 PostAuthor: kas750 » Wed Feb 03, 2010 8:41 pm
heres a link to the main site.Dale has dedicated so much to developing this site. :D
Garn 1
#6 PostAuthor: Garn 1 » Wed Feb 03, 2010 8:54 pm
Kas750, great tip... looks so easy. When you finally put the centre-stand down, you get money from heaven!
RegardZ.
KeithZ1R
#7 PostAuthor: KeithZ1R » Wed Feb 03, 2010 8:56 pm
:shock: Genious :P
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
pertonpc
#8 PostAuthor: pertonpc » Wed Feb 03, 2010 9:49 pm
Thanks guys I will definitely go with the wedging stuff between the coils idea. Will let you all know how it goes and try and get a pic to prove it works!! Thanks again from Mark
jimmock
#9 PostAuthor: jimmock » Fri Feb 05, 2010 10:05 pm
Great idea Kas, but up here in Scotland we would be afraid that the coins would be sprung out and lost for ever under the work bench !!!
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
kas750
#10 PostAuthor: kas750 » Fri Feb 05, 2010 10:10 pm
:lol:
hillbilly
#11 PostAuthor: hillbilly » Sat Feb 06, 2010 7:18 am
thats were copper wire was invented in scotland wasant it,two scots fighting over a penny. :lol: :lol: back to the subject.brute force and sore fingers.
FER
Auld Heedyun
#12 PostAuthor: FER » Sat Feb 06, 2010 8:54 am
See if Jimmock was a real Scot he would borrow the coins of a mate :baby :baby :baby :baby
fer
coldsummer
#13 PostAuthor: coldsummer » Sat Feb 06, 2010 12:01 pm
I've always found it easy to attach the spring to both lugs then fit the pivot bolt(s) using the stand for leverage on the spring. But, the coin trick is a brilliant idea, I've never heard of that before.
irhobotolo
#14 PostAuthor: irhobotolo » Sat Feb 06, 2010 6:23 pm
Jimmock.
Coins are too thick, use washers of various thickness to extend the spring and then fit it and pull the washers out with a pair of pliers when its on the bike.
If you use coins the edges will get damaged as they are softer than washers. I had a right game with my Z650 stands and I am sure that someone was having a laugh when they designed the springs. :P
KeithZ1R
#15 PostAuthor: KeithZ1R » Sun Feb 07, 2010 7:49 pm
FER wrote:See if Jimmock was a real Scot he would borrow the coins of a mate :baby :baby :baby :baby
fer
If Jimmock was areal Scot would he have any mates :!: :lol: :lol:
Keith
:bop :gom
mistaken.
