Page 2 of 3
Posted: Sun Mar 23, 2014 8:47 am
Author: Crofty
Hi GB, not sure if there is anyone in the club that could offer that service. I had SEP Kegworth tip some valves for me. Hence there is an envelope on its way to you with at least on 2.15 shim in. I need stuff in the range of 2.65 to 2.80 now.
Crofty
Posted: Sun Mar 23, 2014 8:54 am
Author: Ginger Bear
Crofty, many thanks for your kind donation, that's the second one this week.
Adrian H has also sent me his significant stash, as he no longer needs them.
.......... I'm beginning to feel like a 'charity case'
Posted: Sun Mar 23, 2014 10:43 am
Author: Crofty
Donation!!!
I need to swap for larger shims GB!!!! Just mentioned there are some smaller sizes in the ones I have posted including a 2.15, you should get them on Tuesday morning.
After having the tips done, I don't have anything close to try in to get a reading to work from, I have sent 16 shims in to get 16 back and go through the trial fit and measure process.
Crofty
Posted: Sun Mar 23, 2014 10:58 am
Author: Ginger Bear
My mistake!
I'll try and get your shims out the same day...... All 16 of em.
Posted: Mon Oct 17, 2016 3:53 pm
Author: Ginger Bear
After some negotiating with Steve Parr & Karen this weekend, Karen has agreed to take over this scheme.
Please contact Karen (Muckmagnet) for your 13mm shims.
Posted: Mon Oct 17, 2016 7:28 pm
Author: kz900B1
Musht', be a schimackover
Posted: Mon Oct 17, 2016 9:00 pm
Author: Al
Thank you.
Re: 13mm Under Bucket Shim Swap Shop. Now Under New Management.
Posted: Wed Jun 07, 2017 2:19 pm
Author: ChrisB
Hello, I have a 265 and a 245 and need a 250 and a 280 large shim please. Pm me the address and I'll pop mine in the post. Many thanks.
Posted: Wed Jun 07, 2017 4:49 pm
Author: ZedHead
Nice one!
Posted: Thu Jun 08, 2017 3:37 pm
Author: ChrisB
Could someone post muckmagnets address or message me. Desperate to get a couple of shims swapped. Alternatively I have a 245 and a 265 and need a 250 and 280 if anyone can help!
Posted: Thu Jun 08, 2017 7:59 pm
Author: wheelysteve
Posted: Fri Jun 09, 2017 4:10 pm
Author: Ginger Bear
ChrisB wrote:Could someone post muckmagnets address or message me. Desperate to get a couple of shims swapped. Alternatively I have a 245 and a 265 and need a 250 and 280 if anyone can help!
memberlist.php?mode=viewprofile&u=4007
Posted: Fri Jun 23, 2017 4:52 pm
Author: DavidZ1R
I have two large shims from my 1000a1, a 270 and a 275. I am after swapping for a 260 and a 265, who is doing the shims, is it Karen and Steve ?
Posted: Wed Sep 13, 2017 6:25 pm
Author: Swirl
Hi who is doing the shim exchange nowadays for the larger Z9 shims thanks Swirl
Posted: Wed Sep 13, 2017 7:03 pm
Author: ADRIAN H
Swirl wrote:Hi who is doing the shim exchange nowadays for the larger Z9 shims thanks Swirl
Jerry - el presidente I believe.
