ENGINE CHANGE
jimmock
ENGINE CHANGE
#1 PostAuthor: jimmock » Thu Nov 03, 2011 10:32 pm
Guyz, need some advice.
I have an old '72 frame. I have all the running gear etc but no engine. I sold it a few years ago for BIG money as the number was Z1E 00163.
I have decided to do something with it.
I intend to put a H***** CX500 lump into it and thus make it shaft drive.
My question is have any of you guyz done this before, and if so, what should I watch out for???
Any advice or pointers would be greatly appreciated.
Thanks.
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
coldsummer
#2 PostAuthor: coldsummer » Thu Nov 03, 2011 10:37 pm
I did the same thing myself a couple of years ago, except the other way round, I had an early 72 Z1 motor (possibly even a late 71) and put it in a cx chassis. It went in pretty easily so I don't think you'll have a problem Jimmock.
PAULJAC47
#3 PostAuthor: PAULJAC47 » Thu Nov 03, 2011 10:38 pm
Great idea Jim,that potent mix of an early Zed frame and the legendary plastic maggot power will surely make one "unique" motorcycle,good luck with your project,look forward to seeing the pics in the projects section.
:roll:
jimmock
#4 PostAuthor: jimmock » Thu Nov 03, 2011 10:41 pm
Thanks for the inspiration guyz.
I'll get the pics as I go along.
Jimmock.
Jimmock. :wnkr
GUYZED
#5 PostAuthor: GUYZED » Fri Nov 04, 2011 12:03 am
Make sure you do Jimmock :snap
#449
Z1000A2 Z650B1
Garn 1
#6 PostAuthor: Garn 1 » Fri Nov 04, 2011 7:13 am
Jimmock, I guess the frame is also a low number and would be worth a bit. I appreciate your enthusiasm to have something different, however, what about another Z motor .. Z900 a4.... Z1R.
Tell me you will not cut the frame up!
RegardZ ~ Garn
jimmock
#7 PostAuthor: jimmock » Fri Nov 04, 2011 7:34 am
Garn 1 wrote:Jimmock, I guess the frame is also a low number and would be worth a bit. I appreciate your enthusiasm to have something different, however, what about another Z motor .. Z900 a4.... Z1R.
RegardZ ~ Garn
Yes. ZIF 00139. Sept 72. With title (log book in UK)
I will only cut what is required and NOTHING else.
I do fancy something "different", and I believe this will be "different".
I reckon it will draw a crowd where ever I take it!!!!
Jimmock.
Jimmock. :wnkr
DDZ900
jimmocks project
#8 PostAuthor: DDZ900 » Fri Nov 04, 2011 7:44 am
jimmock no way you can put a coffee pot motor in 72 z1 frame, :twisted: i would putting a jawa 350 twin motor in much much easyer :hys then put 8" overs in it. :wink:
jimmock
Re: jimmocks project
#9 PostAuthor: jimmock » Fri Nov 04, 2011 2:28 pm
DDZ900 wrote:jimmock no way you can put a coffee pot motor in 72 z1 frame, :twisted: i would putting a jawa 350 twin motor in much much easyer :hys then put 8" overs in it. :wink:
I think the 8" overs would ruin it???
I did consider at one point putting in a SR500 big single, but as it is dry sump I decided against it.
Jimmock.
Jimmock. :wnkr
PAULJAC47
#10 PostAuthor: PAULJAC47 » Fri Nov 04, 2011 2:45 pm
heres a thought how about a suffolk super punch mower engine,would have loads more cred than any H**** motor!!!!
#11 PostAuthor: Rich » Fri Nov 04, 2011 5:18 pm
I suggest you go for a parallelogram swinging arm. use the CX driveshaft on one side, but for that extra bit of nostalgia I would think that a nice piece of Oak for the bottom spar on the other side. For suspension do away with the shocks entirely and use elastic bands between the pivots. Damping being provided by adjusting leather washers on the pivots.
#12 PostAuthor: paul doran » Fri Nov 04, 2011 5:24 pm
Jim ignore them You go and cut up that frame
but fit am MZ250 motor instead
aweome engines :lol: :lol:
jimmock
#13 PostAuthor: jimmock » Fri Nov 04, 2011 5:40 pm
paul doran wrote:Jim ignore them You go and cut up that frame
Iain Marshall, has already offered me one.
Jimmock.
Jimmock. :wnkr
PJ
#14 PostAuthor: PJ » Fri Nov 04, 2011 5:51 pm
Jimmock.
Jim I have a Cossack engine, that would suit that old frame you have!
#15 PostAuthor: paul doran » Fri Nov 04, 2011 6:26 pm
or better again a CZ engine
at least You would be still retaining some of the Z bit
