What's the best primer and paint to use on a master cylinder
Reecy
#1 PostAuthor: Reecy » Sun Jan 29, 2012 7:13 pm
Guys
As the title says
What's the best primer and paint to use when refurbishing a brake master cylinder
Thanks in advance
Reecy
kas750
#2 PostAuthor: kas750 » Sun Jan 29, 2012 8:04 pm
I would get it anodised Reecy.
Reecy
#3 PostAuthor: Reecy » Sun Jan 29, 2012 8:16 pm
Ade,
It's for a z1000a2 with the plastic upper fluid reservoir-can they be anodised?
Who can do it round here???
Steve
kas750
#4 PostAuthor: kas750 » Sun Jan 29, 2012 8:46 pm
Karas in leigh can do the anodising.
http://www.karas.co.uk/
The plastic reservoir should come apart from the master cylinder,it unscrews if yours has the round reservoir.If it is tight i have used an oil filter nylon strap wrench to remove it.
ROZZER
#5 PostAuthor: ROZZER » Tue Jan 31, 2012 6:32 pm
Agree with anodising but if you want a low cost alternative, I used Halfords semi gloss black spray paint, rub down with fine wet/dry paper, thoroughly degrease with thinners then apply 2-3 thin coats, not as durable as anodising but job done for £4 (don't get brake fluid on it). In true jap tradition didn't use primer and finish is spot on. Been on for 3 years now. Same applies to switches and even top yoke, have seen brake calipers done but the finish won't stand up to stones etc so powder coat /anodising better for calipers.
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
DavidZ1R
#6 PostAuthor: DavidZ1R » Tue Jan 31, 2012 7:31 pm
I used black satin alloy wheel paint, good job, cheap as chips, but likewise
DONT :( spill fluid on it :)
ruffle
#7 PostAuthor: ruffle » Wed Feb 01, 2012 1:44 pm
FWIW, PJ1 Satin Case Paint seems to resist DOT4 brake fluid.
steve.w
#8 PostAuthor: steve.w » Wed Feb 01, 2012 4:43 pm
u can get 2 pack in a tin its not affected by brake fluid :)
