Clocks reassembly
jonhunt
Clocks reassembly
#1 PostAuthor: jonhunt » Fri Feb 24, 2012 6:06 pm
What's the order for the assembly back on the bike
As I remember the sleeve with the rubber isolater goes on the back side of the clock mounting bracket.
The rubber is flat one side but has a raise centre on the other. Which way round does this go?
Then, should there be a washer, then split washer, then nut.
Should have taken note when I stripped them
:oops:
z1000puddin
#2 PostAuthor: z1000puddin » Fri Feb 24, 2012 6:22 pm
Jon,
What bike/model ??
Stu
Zed til Dead
jonhunt
#3 PostAuthor: jonhunt » Fri Feb 24, 2012 6:34 pm
z1a/b
#4 PostAuthor: z1bman » Fri Feb 24, 2012 6:34 pm
jonhunt
#5 PostAuthor: jonhunt » Fri Feb 24, 2012 6:39 pm
Thanks guys. Got it right :D
