gsxr1100 k, l or m carbs.
nick pearce
#1 PostAuthor: nick pearce » Mon Mar 19, 2012 6:59 pm
Hi everone does anyone knpw if any of the gsxr1100 k,l or m carbs would fit my z1000j and if so if there would be any power increase. Cheers Nick. :D
N Pearce
#2 PostAuthor: Pigford » Mon Mar 19, 2012 7:09 pm
The spacing is correct - BUT.......... lots of negatives :
The float bowl angle is a bit out.
They're CV type carbs and not easy to tune to suit a different bike.
Throttle cable position/fitting maybe an issue?
If you want more ooooomph from the cabrs - what tuning work has been done to the motor :?:
Extra BHP needs proper engine work & exhaust & valves/head, etc.... Just bolting on bigger carbs is not always the way forward... and CV carbs are not ideal - go for flatslide or smoothbores such as Mikuni RS or VM :wink:
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Tue Mar 20, 2012 9:53 am
Nick,
I think you would be better with slabside 750 29mm flatslide carbs which work well on zeds.
Or like Pigford says smoothbores 29mm/33m depending on your engine spec.
nick pearce
carbs for z1000j.
#4 PostAuthor: nick pearce » Tue Mar 20, 2012 6:10 pm
Thanks everyone, I'll probably go for some smoothbores when money allows. I put my keihin 33's on about 15 years ago straight off my heavily tuned gpz1100 and this alone made a difference just on my standard J motor. :twisted: :D
N Pearce
nanno
#5 PostAuthor: nanno » Tue Mar 20, 2012 7:47 pm
All GSXR-variants you mentioned, will use 40mm carbs, they are CV-flatslides and will have a too big body to fit onto the J-inlet rubbers. Furthermore you will loose quite a bit on the low-end and gain not much near the redline.
Get some VM29SS, if you want quick throttle response and low-end grunt or RS34s or 36 if you're more interested in mid to top.
Cheers,
Greg
PJ
#6 PostAuthor: PJ » Tue Mar 20, 2012 11:06 pm
nanno
#7 PostAuthor: nanno » Wed Mar 21, 2012 5:54 am
Yeah, but swapping one set of BS34s on a Z1000J with another shouldn't make that much of a difference. :wink:
PJ
#8 PostAuthor: PJ » Wed Mar 21, 2012 7:01 pm
Sorry I was thinking of the 30mm VM's
nanno
#9 PostAuthor: nanno » Wed Mar 21, 2012 7:53 pm
Thought so... swapping in BS34s for the old (and often worn out) VMs is a nice upgrade to be honest.
nick pearce
carbs for z1000j.
#10 PostAuthor: nick pearce » Wed Mar 21, 2012 8:21 pm
Thanks again everyone, this has all been very helpful. Cheers Nick.
N Pearce
#11 PostAuthor: chrisNI » Wed Mar 21, 2012 9:09 pm
nanno wrote:All GSXR-variants you mentioned, will use 40mm carbs,
It doesn't make any real difference to any of what's been said, but I think the K and L had 36s the M was the first one with 40s.
JohnC
#12 PostAuthor: JohnC » Thu Mar 22, 2012 8:26 am
I have GSXR1100K carbs fitted to my 77 Z1000A1. They work really well but as said the float heights and main jets need tweaking / changing, and you'll need larger inlet rubbers. I've had them on the bike for about 10 years now without any problems. If I remember they were fitted to a spondon (?) framed zed 1000 which featured in Streetfighters magazine, that was the first time I seen them on a zed.
The bike pulls like a train (1075 Wiseco) and the carbs are easy to balance. Use the standard throttle cable, but you'll only need one cable obvioulsy. I also fitted a high flow fuel tap. Hope this helps.
