Yellowing of chrome
Z1B Alan
Yellowing of chrome
#1 PostAuthor: Z1B Alan » Wed Apr 04, 2012 9:33 pm
As per title the chrome on the headers on my Z1B have yellowed slightly :( mostly on no1 cylinder. Is it possible to polish this off without affecting the finish {dont want to be left with scratch marks in the chrome}.
Garn 1
#2 PostAuthor: Garn 1 » Wed Apr 04, 2012 10:27 pm
Alan, that yellowing is usually the first stage of "bluing" of the pipes and usually caused from excessive heat of that cylinder pipe, which is attributed from mal-tuning. If you have checked that all cylinders are "in tune" then I would look at a topic somewhere in this forum that deals with a special polish that does remove bluing. If it is not too advance it can be done.
I always think a slight discolouring is ok, however, all pipes should look the same!
Regardz.
#3 PostAuthor: kev edwards » Thu Apr 05, 2012 8:22 am
All pipes discolour as long as it's the same across the four it's normal, as for polishing it off everytime' if you do that the chrome gets thinner so my advice is to leave them to go thier own colour .
Garn 1
#4 PostAuthor: Garn 1 » Thu Apr 05, 2012 10:02 pm
Alan , further to my previous post, here is something recent on one of the products I was talking about. There are many more posts on "Blueing" on our own forum... Just hard to find! Perhaps a moderator could help.
<http://www.kzrider.com/forum/2-engine>
RegardZ.
jimmock
#5 PostAuthor: jimmock » Thu Apr 05, 2012 10:09 pm
I always practised this theory......
A cylinder burning oil will run a LOT hotter and thus cause the blueing effect.
Anything that can cause over heat in exhaust gasses will blue the headers.
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
Garn 1
#6 PostAuthor: Garn 1 » Fri Apr 06, 2012 3:16 pm
Alan, have a wade thru these...
Search found 10 matches
Z1OwnersClub GB Forum Index
Forum Topics Author Replies Views Last Post
Bike Help 4 x 4 Doremi exhaust.
[ Goto page: 1, 2 ] DaveZ1A 20 446 Sun Mar 25, 2012 4:50 pm
john_roscoe
Bike Help 1973 Z1
irhobotolo 12 462 Tue Mar 02, 2010 8:23 am
Andy T
Bike Help Pipe colour
[ Goto page: 1, 2 ] mikey 22 740 Mon Jan 25, 2010 2:47 pm
02GF74
Bike Help 81 Z650 F2, carbs, fuelling, jets and pipes
[ Goto page: 1, 2 ] m1ks 16 310 Sat May 16, 2009 8:00 am
mick z1a
Bike Help Bluing of Pipes
Garn 1 8 243 Mon Apr 27, 2009 7:31 pm
paulstrees
Bike Help First ride problems
Z1B Alan 12 252 Wed Apr 01, 2009 8:29 pm
tlc
Bike Help Blueing of pipes
Dodgy Z1B 8 287 Tue Mar 24, 2009 10:01 pm
mikey
Regardz
wilsonsjw11
#7 PostAuthor: wilsonsjw11 » Fri Apr 06, 2012 4:54 pm
There is a product called Blue job and it will supposedly remove blueing from pipes.
Regards
Steve
#8 PostAuthor: Garry.L » Fri Apr 06, 2012 5:21 pm
Should be interesting when you go into the shop and ask the sales assistant for a 'Blue Job'.......
jimmock
#9 PostAuthor: jimmock » Sat Apr 07, 2012 2:49 pm
Garry.L wrote:Should be interesting when you go into the shop and ask the sales assistant for a 'Blue Job'.......
COME ON......
This is supposed to be a specialist bike site?????
I'm shocked.
Jimmock.
Jimmock. :wnkr
#10 PostAuthor: Garry.L » Sat Apr 07, 2012 2:58 pm
COME ON......
I'm shocked.
Jimmock.
:blnk
GEZ635
#11 PostAuthor: GEZ635 » Sun Apr 08, 2012 10:44 am
Got to disagree that all pipes discolour. It is normally because the bike is running too lean and getting too hot so check your mixtue settings. As you know, original pipes have thicker down tubes than the copies and never seemed to blue. We have fitted lots of copy exhausts and never had then discolour but I know how annoying it must be when they do. Blue job polish will work but unless you address the problem the discolouring will just come back.
Gez
#12 PostAuthor: kev edwards » Sun Apr 08, 2012 11:33 am
Double skinned pipes do not suffer, were the early originals double skinned? pipes will always discolour unless your bike is just an ornament, it's the nature of the internal combustion engine.
Steve Cooke
#13 PostAuthor: Steve Cooke » Mon Apr 09, 2012 9:53 am
I have done about 3000mls. on my new original pipes and there is not even a hint of discolouration as yet, it is nearly always down to improper running of the engine ie. too hot. Some cheaper pipes will obviously be a bit more prone to it than some others.
paulstrees
#14 PostAuthor: paulstrees » Mon Apr 09, 2012 11:19 am
GEZ635 wrote:Got to disagree that all pipes discolour. It is normally because the bike is running too lean and getting too hot so check your mixtue settings. As you know, original pipes have thicker down tubes than the copies and never seemed to blue. We have fitted lots of copy exhausts and never had then discolour but I know how annoying it must be when they do. Blue job polish will work but unless you address the problem the discolouring will just come back.
Agree with Ges,I,ve fitted a lot of new replica systems over the last few years and never had a problem,its down to a poor set up and not warming the pipes up a few times before riding
RAYZ1
bluing
#15 PostAuthor: RAYZ1 » Mon Apr 09, 2012 7:17 pm
I fitted replica pipes and before fitting I was advised to soak the insides with used engine oil, the oil burns off quick and leaves an insulating layer which helps prevent blueing - the tip came from a mate who has single skin chrome pipes on his 67 Camaro - apparently its done a lot in the custom car scene
Anyway no blueing as yet
I have also seen blueing on double skin pipes - theyre not beyond discolouration either
Users browsing this forum: bedlow1 and 63 guests
