Seats and Guides fitting - How much ?
#1 PostAuthor: ZedHead » Thu Aug 16, 2012 2:00 pm
How much should it cost to get new seats and guides fitted to a head?
Are there any benefits to getting bronze liners fitted to the existing guides?
#2 PostAuthor: PAULJAC47 » Thu Aug 16, 2012 4:28 pm
Try Sepp at Kegworth,they will fit insert guides to your existing ones work fine,their work is always good and you can courier it to them,i got a very low miles from the states for £200 ish complete with cams etc,or you could give DK at newcastle under lyme a bell,i know guys on here berate them but their Jap engine spares room is huge,all the stuff i have had from them is fine,or put a wanted on here,waht exactly is wrong with your head?...Cheers Paul J
#3 PostAuthor: ZedHead » Thu Aug 16, 2012 5:26 pm
Cheers Paul, I problem is low comp. When i pulled the head off and poured petrol down the ports the exhaust was ok but the intake was pissing out.
I gave the head to John Wyatt, a reputable, local Jap bike restorer. He says the head needs everything. Stems, Guides, Springs, Shell bearings as well as the seats recutting, or more likely, replacing. I reckon the bits alone come to £250 ish alone.
I will follow your advise and advertise for a new head to hedge my bets.
Cheers Dave T
A1John
#4 PostAuthor: A1John » Thu Aug 16, 2012 5:52 pm
If you want to do a proper job you have to bite the bullet and pay the price.
#5 PostAuthor: chrisu » Thu Aug 16, 2012 6:41 pm
you could also talk to buzzard - he did a z900 head for me and it was top notch.
#6 PostAuthor: ZedHead » Thu Aug 16, 2012 6:46 pm
A1John wrote:If you want to do a proper job you have to bite the bullet and pay the price.
I agree John, the question is what is the right price for a top job and when does it become uneconomical?
complete zedness
#7 PostAuthor: complete zedness » Thu Aug 16, 2012 9:27 pm
How are the valve clearances? If you are having to tip the valves to get clearance you need new seats, if not just have them re-cut.
http://www.z1ownersclub.co.uk/forum/vie ... highlight=
This is not a cheap option but in my opinion it's worth spending the money, motor runs soooo much better now :D
Not sure about the bronze valve guide liners. I used genuine Kawasaki replacements.
