Page 1 of 1
Losing oil
Posted: Fri Oct 26, 2012 9:20 am
Author: zman
the bike has been burning and or losing oil.
There is a little bit of smoke out the exhaust so its burning some.Also a bit of a weep around the head gasket.Not sure why as was a new gasket fitted when i put new valves in last winter.
would a compression check tell me if the oil is also leaking into the cylinders.
Is there a way to check if its a valve seal.
lve left it till now as the bike still runs great.
Posted: Fri Oct 26, 2012 9:29 am
Author: garyd
Re check the torque setting on the head...might be slightly loose due to settling down after the rebuild.
The burning oil would need a stripdown to fine where the oils getting in...
Posted: Fri Oct 26, 2012 10:37 am
Author: jimmock
IS THE SMOKE ON HARD ACCELERATION OR OVER RUN??
Posted: Fri Oct 26, 2012 11:44 am
Author: zman
There's smoke on start up and i believe a bit on overrun.can see when on full throttle
Posted: Fri Oct 26, 2012 11:48 am
Author: wilsonsjw11
Did you use quality valve oil seals on the rebuild?
Regards
Steve
Posted: Fri Oct 26, 2012 1:19 pm
Author: zman
To be honest steve.The ones i had ,had only done 500 miles so did not change them
Posted: Fri Oct 26, 2012 2:18 pm
Author: jimmock
Sounds like valve stem oil seals or valve guides to me.
On full choke due to the excessive vacuum, the engine will draw oil in through the valve stem oil seals.
Posted: Fri Oct 26, 2012 4:05 pm
Author: PAULJAC47
Yep sounds like stem seals were they genuine ones fitted?Ditto was the head gasket and head to barrels o ring gen? all classic cases of oil leaks if reporos used!!!!!!
Posted: Sat Oct 27, 2012 8:35 am
Author: toycollector10
There are posts on this forum about over filling with oil. The Z's like the oil to be sitting near the bottom of the two marks. If it's up to the top it just gets blown off until it's burned down to the lower mark and that's where it stays.
