starter clutch prob
baz
starter clutch prob
#1 PostAuthor: baz » Fri Feb 06, 2015 4:18 pm
starter motor has suddenly started spinning the engine over a couple of times then disengaging, making a wizzing noise then a loud clunk, ok on the kick start.
starter motor or starter clutch problem ??????????
#2 PostAuthor: Pigford » Fri Feb 06, 2015 4:52 pm
Sounds like the 3 x rollers & springs in the rotor unit :|
#3 PostAuthor: z1bman » Fri Feb 06, 2015 5:07 pm
definitely starter clutch
baz
#4 PostAuthor: baz » Fri Feb 06, 2015 5:12 pm
cheers lads :(
thought so but always better to ask :D
#5 PostAuthor: z1bman » Fri Feb 06, 2015 5:17 pm
make sure the three allen bolts have not worked loose & i would replace them with new bolts & loctite them in
PAULJAC47
#6 PostAuthor: PAULJAC47 » Fri Feb 06, 2015 5:24 pm
Whats the bike?
baz
#7 PostAuthor: baz » Fri Feb 06, 2015 6:08 pm
PAULJAC47 wrote:Whats the bike?
hi paul
its my special, Z1 motor bored out to 1100
PAULJAC47
#8 PostAuthor: PAULJAC47 » Fri Feb 06, 2015 6:11 pm
Yep sounds like the starter clutch,all the above have said,was just checking in case was a 650,not so straightforward with them....Paul J
baz
#9 PostAuthor: baz » Fri Feb 06, 2015 6:17 pm
I think it being bored out to 1100cc doesn't help !!!!!!!!
jez1100r
#10 PostAuthor: jez1100r » Sat Feb 28, 2015 5:39 pm
are all springs and roller the same for all 1100 /1000 modles
#11 PostAuthor: z1bman » Sat Feb 28, 2015 6:33 pm
they are the same for all models make sure the surface on the gear is perfectly round otherwise it will fail again in a short time
jez1100r
#12 PostAuthor: jez1100r » Sun Mar 01, 2015 9:43 am
the gear is worn. is it worth replacing the clutch holder .that all looks ok but being black it is a job to tell
i see z power do a kit that includs a holder .
#13 PostAuthor: z1bman » Sun Mar 01, 2015 10:17 am
jez1100r
#14 PostAuthor: jez1100r » Sun Mar 01, 2015 10:37 am
Thanks mine is an 1984 z1100r the links show up to 1983 are they all the same on later modles
#15 PostAuthor: z1bman » Sun Mar 01, 2015 10:50 am
z1000 r1/r2 is different from the z1100r1 :cry: :cry: :cry:
