Fitting electronic ignition?
sprint
#1 PostAuthor: sprint » Fri May 29, 2015 9:02 am
I am looking to install electronic ignition to my A4.
Looking around there only seems to be a couple of alternatives, Boyer and the Dyna S?
Which is the best and more importantly the most reliable and easy to setup and install?
I have read that the Dyna system draws a fairly high current that can lead to battery failure if run with lights, is that the case and members experience?
I also note that the Dyna system retains the mechanical advance unit, does that not retain some of the inherent issues associated with the original points system with 'sticky' inconsistent tickover and poor low revs pick up and a full advance limit of 2500 revs?
Everybody seems to find fault with Boyer is that really justified and since it provides a fully electronic/digital advance curve does it not provide a more stable tick over and pick up together with a full advance curve above 2500 revs?
KeithZ1R
#2 PostAuthor: KeithZ1R » Fri May 29, 2015 9:15 am
Shop about and get yoursen an Newtronic optical system ( Piranha) and pair it with a set of 3 ohm Dyna coils or not if you prefer, you wont regret it and you wont need a second mortgage to procure same :D
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
sprint
#3 PostAuthor: sprint » Fri May 29, 2015 9:53 am
Thanks for the reply, but they do not list one for the Z900's?
KeithZ1R
#4 PostAuthor: KeithZ1R » Fri May 29, 2015 10:02 am
As the unit uses the original advancer it aint difficult to deal with
http://www.newtronic.co.uk/images/pdfs/ ... ion-V1.pdf
Keith
:bop :gom
mistaken.
becker
#5 PostAuthor: becker » Fri May 29, 2015 10:23 am
Had Boyer fitted for a couple of years on my Z1000, but it failed this year. It was Ok when running, bike ran fine.
Have now fitted a Dyna-S after someone loaned me one to try - its more tidy option - no electronics box to fit somewhere. Bike runs fine on it.
Only an observation - bike does seem to start easier with the Dyna - doesn't need to spin as many times before firing up.
When life hands you lemons, reach for the vodka.
Z1B (in Z1A colours), Z1000A1, ZRX1100 C4, Suzuki TS125J (being restored), Suzuki T125J (in boxes), Garelli Rekord MKII (awaiting restoration), most of a Garelli Rekord MKI
wilsonsjw11
#6 PostAuthor: wilsonsjw11 » Fri May 29, 2015 10:33 am
Sprint,
Dyna S,Dyna 3ohm coils and Wired George mod for better all round starting,tickover and performance with full 12volts on the LV side of the
coils.
Regards
Steve
sprint
#7 PostAuthor: sprint » Fri May 29, 2015 10:46 am
wilsonsjw11 wrote:Sprint,
coils.
Regards
Steve
Thanks for the reply. Was looking to use the std Kwak coils, certainly initially, due to the extra cost.
I assume it is OK with the std Kwak coils?
sprint
#8 PostAuthor: sprint » Fri May 29, 2015 10:47 am
becker wrote:Had Boyer fitted for a couple of years on my Z1000, but it failed this year. It was Ok when running, bike ran fine.
Thanks for the reply. How did you find the fitting and is tick over and pick up OK?
#9 PostAuthor: ZedHead » Fri May 29, 2015 10:56 am
I fitted Dyna S to mine last year. It was dead easy even for me! The bike has never ran better since i got it :D
PM me if you need help getting one
becker
#10 PostAuthor: becker » Fri May 29, 2015 10:57 am
Fitting is dead easy - there is a thread somewhere on the forum which details it and someone else asked recently, to which I also replied - you just need to create a couple of feet of 3 wire loom to extend the Dyna wires to connect with the ones under the tank.
Tick over and pick are both excellent - tick over is consistent and pick-up seems fine - no different than with the Boyer to be honest - just don't have the popping/banging on rolling off.
I fitted some new standard Kwak coils when I fitted the Boyer a couple of years ago and they still work great with the Dyna - nice strong spark.
sprint
#11 PostAuthor: sprint » Fri May 29, 2015 11:15 am
Thanks for the reply and advice.
Is not the lead that is supplied with the unit not long enough to to reach the connectors under the tank?
#12 PostAuthor: chrisu » Fri May 29, 2015 11:20 am
Lead is long enough... Just
sprint
#13 PostAuthor: sprint » Fri May 29, 2015 11:22 am
chrisu wrote:Lead is long enough... Just
#14 PostAuthor: ZedHead » Fri May 29, 2015 11:27 am
A bit of tricky threading job but the lead from the Dyna S will reach the connectors under the tank.
http://www.powercommander.com/downloads ... -1_2-2.pdf
http://www.z1ownersclub.co.uk/forum/vie ... light=dyna
becker
#15 PostAuthor: becker » Fri May 29, 2015 11:36 am
Needed to extend my wires from under the tank.
Dyna came with a couple of feet of wire - but unless I ran them straight up the side of the engine :shock: they wouldn't reach - to loom them in nicely behind the engine needed to create a small piece of 3 wire loom.
As others have found, yours might not need it.
Users browsing this forum: No registered users and 77 guests
