Gents,
I've been scouring t'interweb and searched to see if I can find the cam specs (or a service manual) for a GPz1100B2, where other than one post on another forum I appear to have failed dismally...
The post stated a lift of 8.8mm and duration of 288 degrees for both (three grooves on the raised boss). Could anyone please confirm if this is correct?
Coose
GPZ1100B2 cam specs
Re: GPZ1100B2 cam specs
Found it hiding in the back of the manual - it's correct.
I thought 1100Bs had the same cans as 1000Js, but I've never bothered confirming this.
Julian_Boolean wrote:I thought 1100Bs had the same cans as 1000Js, but I've never bothered confirming this.
I think the B1 might, but the B2 has the R2 cam...
Gavin wrote:How can you tell the difference ?.
Measure them, I wouldn't rely on the markings on the cam
Next question
What part of the cam lobe do I measure and what measurement should I expect for a R2 cam and a J cam
Z1000 MK2
Z1300 DFI
Z1300 DFI
For the lift you need to subtract the base circle from the overall cam height or use a dial gauge on the cam lobe as it rotates.
For the duration you need a dial gauge on the cam bucket and a degree wheel on the crank.
Thanks for the reply Rob.
The cams are still in in the head and I don’t have the gauges you suggest. I did a rough measurement on the upper lobe
with a rule (pic), is this what I need to measure as I get approx 11mm
Z1000 MK2
Z1300 DFI
Z1300 DFI
Gavin wrote:Thanks for the reply Rob.
No! The lift will be less than that.
11mm is race cam territory.
More like 8.6 to 9mm ish.
The base circle is a larger dia than the core of the cam that you are measuring from so the lift will be less.
You need to measure across the cam from the peak of the lobe through to the bottom of the cam then measure the base circle and subtract that figure to get the lift..
If you have some Verniers you should be able to take those measurments with the cam in situ.
Users browsing this forum: Big Fluff and 189 guests
