Z1a Engine Mounting Bolts.
BigZCas
#1 PostAuthor: BigZCas » Thu Feb 01, 2018 11:25 am
Please could anyone confirm if this is correct as per original or advise other ?
So many conflicting pictures :??
The 3 off long bolts that pass through left to right -
No washers under the heads, spring washer and lock nut on the thread side.
The 2 off bolts for the front engine mount to frame -
No washers under the heads, spring washer and nut on the threaded side.
The 2 off 12mm Bolts -
Spring washers under the head.
The 2 off 8mm Bolts -
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Re: Z1a Engine Mounting Bolts.
#2 PostAuthor: z1bman » Thu Feb 01, 2018 11:40 am
yes that's all correct
BigZCas
#3 PostAuthor: BigZCas » Thu Feb 01, 2018 1:21 pm
Thank You z1bman :D :D
Past 5 Years
1976 KZ1000a1, Red
