Please could anyone confirm if this is correct as per original or advise other ?
So many conflicting pictures
The 3 off long bolts that pass through left to right -
No washers under the heads, spring washer and lock nut on the thread side.
The 2 off bolts for the front engine mount to frame -
No washers under the heads, spring washer and nut on the threaded side.
The 2 off 12mm Bolts -
Spring washers under the head.
The 2 off 8mm Bolts -
Z1a Engine Mounting Bolts.
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
Re: Z1a Engine Mounting Bolts.
yes that's all correct
Thank You z1bman
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Users browsing this forum: Skid Mark and 238 guests
