Air Filter
Air Filter
Was thinking about replacing the stock filter on my z1000 A2 with K&N pod types which I think look good - Is this easy to do and what else do I need to consider.Are K&N the best option and what size do I need to look for ? Cheers all.
Re: Air Filter
Standard air box is better than pods - less likely to get blocked.
Link to k&n pod filters, not cheap.
https://www.knfilters.co.uk/mobile/mPro ... ct=RC-2454
Re: Air Filter
Thanks - Would the carb jets need any changes ?
Re: Air Filter
Yes carbs would need re-jetting
Re: Air Filter
kev edwards wrote:Yes carbs would need re-jetting
+1.
Re: Air Filter
ADRIAN H wrote:Standard air box is better than pods - less likely to get blocked.
Do you need to trim the side covers with these one's??
Users browsing this forum: Stevo1015 and 29 guests
