KZ1000A1 Throttle cable bracket
- Regular Poster
Help needed please.
The two riveted parts of my throttle cable bracket have become a bit loose. Do they respond well to a large hammer and punch or is it best to drill the rivets out and replace with nuts and bolts?
Thanks Roger
1976 KZ1000A1, 1981 KZ1100 Shaft+Steib TR500 sidecar (ongoing), 1942 Motoguzzi 600U, 1948 Moto Guzzi GTV, 1952 Moto Guzzi Ercole (in bits), 1953 Nimbus, 1986 Moto Guzzi V65 Lario (in need of TLC), 1988 Moto Guzzi Mk V Le Mans
- wheelysteve
Re: KZ1000A1 Throttle cable bracket
There should be some movement in them to allow the closing cable action to work properly.
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Cleaning my carb bits up, no play in the rivets on mine, solid.
- Attachments
- 20180208_152349.jpg (93.64 KiB) Viewed 2018 times
The play is normal.
That's why there is a spring between them and the back plate near where they bolt on with the 2 countersunk screws.
It's to provide a bit of cushion for the closing cable.
The holes in the half of the bracket that isn't bolted down are larger than the rivets to allow movement.
- Regular Poster
Thanks all for the detailed response. I'll leave well alone. For info. I bought Mark Tillers lovely KZ1000A1 a couple of weeks ago. It's great to have it in the shed. I've wanted one for a long time. Of course I can't help but have a fiddle...
Roger
Roger
Yes, lubed the braket I cleaned up, and yes there is play in it now.
Users browsing this forum: Grog and 47 guests
