Running rufff
Running rufff
Hi all , just got a 76 kz 9. Non runner, I’ve got it running , after carb refurb new coils points & plugs , static timed, runs ok at about 2K don’t like to tick over , and won’t start without Easystart down the carbs, any suggestions on what next???
- ZedHead
Re: Running rufff
sounds like ya carbs still,float hieghts ,balanced em ,tick over ajusted ? plug leads right way? fresh fuel?
Re: Running rufff
Despite the carb refurb it sounds like the pilot fuel circuit.
Pilot controls from zero to around 2k rpms.
I'd have another look at the pilot jets and the drilling that emerges in the venturi .
It's also common for the pilot screw tips to break off and block the pilot drillings.
Re: Running rufff
Thanks I’ll check it out
Re: Running rufff
Hi Trad 1
sounds indeed like a carb problem.
Take them off, strip them completely, clean them ultrasonically, 2 times or more, and afterwards use compressed air to clean out all the small tubes in the carbs. Put them together again, give them an initial static synchronisation, make sure the floater height is correct and mount them again on the bike. Perform a final synchronisation.
If done correct the bike should perform well.
If you can't do it youself, find someone you can trust to do it.
Just remember that a shiny carb on the outside is not a guaranty for a clean carb on the inside !
Good luck!
Greetings
Good luck!
Greetings
- warren3200gt
Re: Running rufff
Trad, if you need a hand, I'm not far from you.
PUM 488 June 2023
Re: Running rufff
As others have said, it does sound like blocked pilot jets, but could be ignition timing
- Regular Poster
Re: Running rufff
After I've put carbs in the ultrasonic bath I tend to use carb. cleaner spray to make sure that all the drillings are completely clear - you can see the fluid exiting as it should (be careful not to get an eye full). After all it's such a pain in the arse to get to this stage, it's worth making doubly sure.
1976 KZ1000A1, 1981 KZ1100 Shaft+Steib TR500 sidecar (ongoing), 1942 Motoguzzi 600U, 1948 Moto Guzzi GTV, 1952 Moto Guzzi Ercole (in bits), 1953 Nimbus, 1986 Moto Guzzi V65 Lario (in need of TLC), 1988 Moto Guzzi Mk V Le Mans
Re: Running rufff
Probably carbs as said if it runs reasonably well on easystart.
I would also do a compression check sooner than later. Most old engines will need some work if not already attended to. It is good to get this out of the way and problems here can send you on merry dance and your carbs will never set up properly. Make sure you follow the manual, charged battery, hot engine and open throttle etc..
- Regular Poster
Re: Running rufff
This is why I love thus club - a simple question asked by a new member, brilliantly answered in a few replies with sound advice.
No piss taking - no armchair experts giving their opinion on something they know nothing about.
Well done!
Oh! and its definitely the pilots or not synced.
Well done!
Re: Running rufff
Pigford wrote:Are rubbers good - check for air leaks.
Maybe Jimmock can answer that one .. actually best not
Re: Running rufff
Thanks for everyone's replys really helpful , and the offer of help, , so it's back to the garage this weekend
Re: Running rufff
as already mentioned blocked pilot system but it is also important to check the valve clearances & do a compression test. if the valves are tight it will struggle to draw in any fuel
Re: Running rufff
warren3200gt wrote:Trad, if you need a hand, I'm not far from you.
Good on ya Warren......... 10/10
Users browsing this forum: No registered users and 155 guests
