Mind the gap
Mind the gap
Need to get my z1000 down an access way that is a couple of inches narrower than the max bars width - Can I just loosen handlebars and move slightly to reduce width ?
Re: Mind the gap
The bars will still be the same width! but i have a hacksaw you can borrow
- warren3200gt
Re: Mind the gap
If your cables are long enough, take the bars caps off and twist the bars. You'll need to steer by the forks though. Plenty of anti scratch padding on the tank.
PUM 488 June 2023
Re: Mind the gap
Yeah thanks Warren that's what i was thinking - Cheers.
Re: Mind the gap
I have the same problem with an ally way down the side of my house to my shed
if the walk way is flat my solution was a skate board and two people font wheel on the skate board wheel turned and a strap around the wheel and board for me it works very well and with practice I can do it on my own
ow tip put bike in gear and uses the clutch/Engine for braking
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
Re: Mind the gap
If they’re the standard bars they really should have an inch cut off each end it makes them look better and that’s what the AMA racers used to do back in the day when they had to use standard bars.
The switchgear will pull in quite a bit. You should check first but it’s about an inch each side.
- damien.wrl
Re: Mind the gap
Wheelie it The you can turn the handlebars
Re: Mind the gap
Or sledgehammer on the brickwork
Re: Mind the gap
warren3200gt wrote:If your cables are long enough, take the bars caps off and twist the bars.
That's what I do to get bikes from my workshop to the adjacent room. I'm doing it enough now that I need to fit a wider door!
Re: Mind the gap
step one measure gap
step two procure a set of bars and cut them to width
step three remove original bars and wrap them up and secure to bike
step four replace original bars with cut down version
step five steer and manoeuvre bike down allyway
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Re: Mind the gap
Back in the day my mate used to build chops in his living room, he had cut down drag bars which he would use just to get the finished bikes out of the living room. He built several nice chops in there, after his missis left.
1975 Kawasaki Z1B
1979 Triumph Bonneville T140D
1969 BSA B25 Starfire
Re: Mind the gap
AlanB wrote:Need to get my z1000 down an access way that is a couple of inches narrower than the max bars width - Can I just loosen handlebars and move slightly to reduce width ?
SIMPLE Just 2 inches of the end of ruler !!!!!!!!!!! should be right to go then .
Users browsing this forum: No registered users and 236 guests
