CALIPER DUST BOOT RING Z1000A1 38MM
Any know who stocks these..CALIPER DUST BOOT RING Z1000A1 38MM,thet are the press in rings that retain the boot rubber seals, zpower stock z1 type but think they may be 43mm..Ta Paul J
Re: CALIPER DUST BOOT RING Z1000A1 38MM
z1000 should have 42mm pistons 38 mm are for early triples
Hi
The Z1000A1 had 42 mm brake caliper pistons (calipers mounted in front of the front fork as on the Z900A4)).
the 38 mm brake caliper piston was used on the Z1R (D1) and some Z1000A2 had those allso.(calipers mounted behind the front fork)
Ask Z-power for the availability of those, I bet they can help you.
Greetings
Greetings
my z1000a1 has 42mm pistons and the ones from z power fit great
